ballsdeep Posted December 28, 2013 Share Posted December 28, 2013 (edited) Iv been suffering from an awful grinding noise when I pull away/reverse. it doesn't happen all the time or in any other gear? I suspected it could be a seized caliper? so I took the weight off the wheels and spun each one and the front drivers side was sticking so I refurb'd all four calipers hoping that was the problem, but As I pulled away it was worst than ever, probably because it had been sat for awhile! There's a slight feel of it dragging when it happens?? I though it was coming from the front passenger wheel but each time I hear it I change my mind?? Can't get it in the garage to have a look untill after the new year so any tests I can do to eliminate things might help for now. Cheers EDIT: convinced its the clutch now, similar sound To a seized caliper? But the clutch doesn't slip and has done less than 800 miles! Edited January 29, 2014 by ballsdeep (see edit history) Quote Link to comment Share on other sites More sharing options...
tooquicktostop Posted December 28, 2013 Share Posted December 28, 2013 did you change the discs when you refurb'd the calipers Quote Link to comment Share on other sites More sharing options...
ballsdeep Posted December 28, 2013 Author Share Posted December 28, 2013 Yep all four calipers were replaced. The rears where quite tough to get off! Quote Link to comment Share on other sites More sharing options...
ballsdeep Posted December 28, 2013 Author Share Posted December 28, 2013 My bad meant discs changed Quote Link to comment Share on other sites More sharing options...
Rich.2211 Posted December 28, 2013 Share Posted December 28, 2013 Is your exhaust or downpipe catching anywhere? Mine was doing this because the exhaust was catching on the rear subframe Quote Link to comment Share on other sites More sharing options...
tooquicktostop Posted December 28, 2013 Share Posted December 28, 2013 Could be a wheel bearing, any play in the wheel at all Quote Link to comment Share on other sites More sharing options...
ballsdeep Posted December 28, 2013 Author Share Posted December 28, 2013 Both Rears have very slight play I think it was top and bottom? If the bearing had gone wouldn't I hear it when driving? As for the exhaust that's all ok. Quote Link to comment Share on other sites More sharing options...
tooquicktostop Posted December 28, 2013 Share Posted December 28, 2013 I had a very loud grind on first movement in my Golf, it was not audible at speed, wheel bearing was totally knackered when checked and changed Quote Link to comment Share on other sites More sharing options...
ballsdeep Posted December 28, 2013 Author Share Posted December 28, 2013 Ok cheers pal il give it a once over again tomorrow. It is very loud on first movement and then most times after Iv come to stop then pull away again. How easy are they to change? Quote Link to comment Share on other sites More sharing options...
tooquicktostop Posted December 28, 2013 Share Posted December 28, 2013 Ok cheers pal il give it a once over again tomorrow. It is very loud on first movement and then most times after Iv come to stop then pull away again. How easy are they to change? I would have no idea, I am allergic to spanners ! Quote Link to comment Share on other sites More sharing options...
ballsdeep Posted December 28, 2013 Author Share Posted December 28, 2013 Found this but I need a break from working on it so off to the garage it goes!! http://www.mkivsupra.net/vbb/showthread.php?217396-Wheel-Bearing-Replacement Quote Link to comment Share on other sites More sharing options...
ballsdeep Posted December 30, 2013 Author Share Posted December 30, 2013 So managed to get it in the garage today and he thinks it's the clutch? I went in to bleed the brakes up properly so only spent 5mins checking the noise out but it's not a wheel bearing noise! It was my first clutch install so I'm hoping its something silly that I should have done? Here's things I now know I should have done.. 1/ Use the correct grease not multi purpose bearing grease 2/ grease the clutch fork which I didn't 3/ replace the spigot bearing (in my defense the one in looked ok) 4/ on the fidanza flywheel the contact surface is replaceable and should have been changed! Looks like the gearbox is coming off again Quote Link to comment Share on other sites More sharing options...
Rich.2211 Posted December 30, 2013 Share Posted December 30, 2013 So managed to get it in the garage today and he thinks it's the clutch? I went in to bleed the brakes up properly so only spent 5mins checking the noise out but it's not a wheel bearing noise! It was my first clutch install so I'm hoping its something silly that I should have done? Here's things I now know I should have done.. 1/ Use the correct grease not multi purpose bearing grease 2/ grease the clutch fork which I didn't 3/ replace the spigot bearing (in my defense the one in looked ok) 4/ on the fidanza flywheel the contact surface is replaceable and should have been changed! Looks like the gearbox is coming off again I feel your pain, mine has got to come off again too but I think I'm going to wait until it's back on the road and use the two post ramp at work.. touch wood. Quote Link to comment Share on other sites More sharing options...
ballsdeep Posted December 30, 2013 Author Share Posted December 30, 2013 I learnt my lesson the first time, did mine on axel stands and ended up pinned with the gearbox on my leg. Gets very heavy if it doesn't go right the first time!! You must be stalking the post man by now isn't your whifbitz kit on its way? I'm Saving up for his manifold! Quote Link to comment Share on other sites More sharing options...
Rich.2211 Posted December 30, 2013 Share Posted December 30, 2013 I learnt my lesson the first time, did mine on axel stands and ended up pinned with the gearbox on my leg. Gets very heavy if it doesn't go right the first time!! You must be stalking the post man by now isn't your whifbitz kit on its way? I'm Saving up for his manifold! Me and Josh swapped his gearbox on axle stands a few months back and was just a PITA lying on the floor. It's too cold for that this time of year really. The 2 post ramp will be luxurious in comparison Yeah Paul originally hoped he may be able to get it out to me for Christmas but I messaged him recently and it will be mid January for the bulk of the kit and end of January for the SMIC and pipework. Bit of a sack ache but there's no rush as it's off the road until March anyway. Means I can do a load of other tinkering like new front lip, underseal, calipers etc. Quote Link to comment Share on other sites More sharing options...
fastcar Posted December 31, 2013 Share Posted December 31, 2013 (edited) Is the stage 3 a puck clutch by any chance? Just looked at there website to see if it was. I would say it is the clutch itself the puck clutch is a nightmare on normal day to day driving. I have or did have a competition puck clutch and that made the same kind of noise as you describe, in reverse was the worse it would judder like mad and sound like it was chewing the flywheel to pieces. Once the car was moving it was fine, was best when really giving it the beans then it worked great. It's more of a track/drag sort of clutch not a road clutch. Edited December 31, 2013 by fastcar (see edit history) Quote Link to comment Share on other sites More sharing options...
ballsdeep Posted January 29, 2014 Author Share Posted January 29, 2014 Little update.. So as well as my clutch grinding/screeching on take off my clutch pedal started to get sticky yesterday and then today it didn't come back up. Im guessing its a master or the slave cylinder issue since the fluid hasn't dropped! What I'm wondering is if the slave cylinder fails could it cause the release bearing to make the grinding noise I'm hearing? Quote Link to comment Share on other sites More sharing options...
