Timlowthian Posted December 28, 2013 Share Posted December 28, 2013 Hi All Having issues with one of the Supra's I have here at the moment. Its a standard NA but it will not stay running. When you start the car it fires up but then the revs just drop and the engine stalls, it makes no difference if you keep your foot on the throttle as it doesn't do anything. I have swapped the complete throttle body (including tps and icv) with a known working one from another NA and has the exact same problem. Anyone have any suggestions or ideas what could be causing this? Quote Link to comment Share on other sites More sharing options...
David P Posted December 28, 2013 Share Posted December 28, 2013 Could be fuel pump ECU, bypass it in the diagnostic port to find out. Quote Link to comment Share on other sites More sharing options...
Timlowthian Posted December 28, 2013 Author Share Posted December 28, 2013 Ok so I just tried that by bridging the FP and B+ in the diagnostic port with a paperclip and still the same result. Quote Link to comment Share on other sites More sharing options...
David P Posted December 28, 2013 Share Posted December 28, 2013 Is it lack of fuel or lack of spark? Can you hear the fuel pump working? Quote Link to comment Share on other sites More sharing options...
Timlowthian Posted December 28, 2013 Author Share Posted December 28, 2013 After listening in the boot you can hear the pump running for a second after the engine dies. I have not pulled the leads and checked for spark yet. Quote Link to comment Share on other sites More sharing options...
DodgyRog Posted December 28, 2013 Share Posted December 28, 2013 Check the Fuel Filter isn't blocked up as well Quote Link to comment Share on other sites More sharing options...
David P Posted December 28, 2013 Share Posted December 28, 2013 Check the vacuum hose to MAP sensor and/or connector/plug and/or the sensor. Check igniter body is earthed. And/or are there any fault codes? Quote Link to comment Share on other sites More sharing options...
