Andrew Posted March 15, 2003 Share Posted March 15, 2003 Fitting a Turbo timer at the moment and just want to check where I "T" off the vaccum pipe. The one I have located is on the passenger side of the engine, it has 3 wires going in to it and a vaccum pipe underneath........am I in the right place and do I "T" the vaccum pipe off under the sensor? If anyone has pictures it would be most appreciated. Thanks, Andrew. Quote Link to comment Share on other sites More sharing options...
Thorin Posted March 15, 2003 Share Posted March 15, 2003 T it into the rubber pipe going from 'A' to 'B', the B end connects at the underside of the pressure sensor 'C'. Quote Link to comment Share on other sites More sharing options...
Andrew Posted March 15, 2003 Author Share Posted March 15, 2003 Cheers Michael top man, now all I have to do is get the bloody vaccum pipe through the firewall Quote Link to comment Share on other sites More sharing options...
Thorin Posted March 16, 2003 Share Posted March 16, 2003 Originally posted by Andrew Cheers Michael top man, now all I have to do is get the bloody vaccum pipe through the firewall Easy enough, I poked it though the rubber grommet down near the steering column. Easier if you have someone else to help grab the other end while you are poking it through from the drivers footwell. Quote Link to comment Share on other sites More sharing options...
Steve Cargill Posted March 17, 2003 Share Posted March 17, 2003 There are some piccies of how I did mine http://www.cargills.demon.co.uk/supra/mods.html#BoostGauge Quote Link to comment Share on other sites More sharing options...
Andrew Posted March 17, 2003 Author Share Posted March 17, 2003 Eventually I ran the vaccum pipe through the yellow plug/grommet down by the accelerator pedal to the right, hopefully that was an ok place to poke a hole in Quote Link to comment Share on other sites More sharing options...
