ibby Posted December 23, 2013 Share Posted December 23, 2013 Right guys.. as stupid as this sounds.. If you were going to install a AEM / or another manufacture wideband afr sensor, would you simply remove the stock o2 unit and install the new unit? (this is on a stock car with no modfications, eg no new downpipe). This is really to have it installed for TTC mode. Thanks! Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted December 24, 2013 Share Posted December 24, 2013 Ideally you'd need another boss welded onto the exhaust, although the AEM can output a simulated narrowband signal. Quote Link to comment Share on other sites More sharing options...
ibby Posted December 24, 2013 Author Share Posted December 24, 2013 Thanks pal.. Is this the prodct? http://www.ebay.co.uk/itm/GENUINE-AEM-WIDEBAND-AIR-FUEL-RATIO-GAUGE-CONTROLLER-O2-SENSOR-KIT-30-4100-/271326381729?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3f2c5006a1 Thanks Quote Link to comment Share on other sites More sharing options...
FOSTA Posted December 24, 2013 Share Posted December 24, 2013 Thanks pal.. Is this the prodct? http://www.ebay.co.uk/itm/GENUINE-AEM-WIDEBAND-AIR-FUEL-RATIO-GAUGE-CONTROLLER-O2-SENSOR-KIT-30-4100-/271326381729?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3f2c5006a1 Thanks That's the fella! That is also very cheap! I'm sure I paid £250 for mine although it was like nearly 4 years ago now! You get a weld on bung with that kit so just take it to any welder or exhaust shop and get them to drill a hole and weld that bung on and your sorted Quote Link to comment Share on other sites More sharing options...
ibby Posted December 24, 2013 Author Share Posted December 24, 2013 That's the fella! That is also very cheap! I'm sure I paid £250 for mine although it was like nearly 4 years ago now! You get a weld on bung with that kit so just take it to any welder or exhaust shop and get them to drill a hole and weld that bung on and your sorted I noticed they have come down in price! Quote Link to comment Share on other sites More sharing options...
james_cbr Posted December 24, 2013 Share Posted December 24, 2013 I got mine for 250 where would you recommend best place to fit bug is 1st decat ? Quote Link to comment Share on other sites More sharing options...
fastcar Posted December 24, 2013 Share Posted December 24, 2013 Will have to be in the 2nd decat as from memory you have to be a certain distance from the turbo to reduce the risk of damage to the sensor Quote Link to comment Share on other sites More sharing options...
james_cbr Posted December 24, 2013 Share Posted December 24, 2013 hum I would but then im swaping the second cat back in for mots would not just above the flange between the cats on the first be just about ok ? Quote Link to comment Share on other sites More sharing options...
fastcar Posted December 24, 2013 Share Posted December 24, 2013 (edited) hum I would but then im swaping the second cat back in for mots would not just above the flange between the cats on the first be just about ok ? The actual sensor is on a plug that sits under the car by you exhaust. So when you change the decat for the cat you can just unplug it. All that will happen is your AEM gauge will just read 14.2 or something like that. I'm sure it's says in the manual that the sensor should be at least 32 or 42 inches from the turbo housing I can't remember now. Will try and find the instruction and let you know. It should be at least 36 inches downstream of the turbo Edited December 24, 2013 by fastcar (see edit history) Quote Link to comment Share on other sites More sharing options...
ibby Posted December 24, 2013 Author Share Posted December 24, 2013 The actual sensor is on a plug that sits under the car by you exhaust. So when you change the decat for the cat you can just unplug it. All that will happen is your AEM gauge will just read 14.2 or something like that. I'm sure it's says in the manual that the sensor should be at least 32 or 42 inches from the turbo housing I can't remember now. Will try and find the instruction and let you know. It should be at least 36 inches downstream of the turbo you number 1! brill info Quote Link to comment Share on other sites More sharing options...
fastcar Posted December 24, 2013 Share Posted December 24, 2013 you number 1! brill info Quote Link to comment Share on other sites More sharing options...
