SupraLEDrears Posted December 22, 2013 Share Posted December 22, 2013 Hi guys I hope someone had a similar problem. If it rains heavily, I get water leaking in somewhere on the left of the boot. It collects in the cover of the bootlid so when I open it, the water drains out. It's not much, but still an annoyance. I've taken the plastic off but cant see there it's coming in. Thought it might be from the the spoiler bolts? Any help appreciated Quote Link to comment Share on other sites More sharing options...
listy Posted December 22, 2013 Share Posted December 22, 2013 Most likely spoiler bolts dude. Quote Link to comment Share on other sites More sharing options...
Fitz Posted December 22, 2013 Share Posted December 22, 2013 Mine does this, open the boot and water on the left hand side pours out from the plastic cover onto the left hand side of the boot. Quote Link to comment Share on other sites More sharing options...
Fizzy T Posted December 22, 2013 Share Posted December 22, 2013 Same here but on both sides. Quote Link to comment Share on other sites More sharing options...
listy Posted December 22, 2013 Share Posted December 22, 2013 As I said guys, probably the spoiler bolts. If not, check the seals around the rear window, as if that is leaking anywhere, the water will collect in the trim I reckon. Quote Link to comment Share on other sites More sharing options...
SupraLEDrears Posted December 22, 2013 Author Share Posted December 22, 2013 thanks ill have a look Quote Link to comment Share on other sites More sharing options...
rg500 Posted October 9, 2016 Share Posted October 9, 2016 Has anyone solved this problem as I have the same thing happened to me. Quote Link to comment Share on other sites More sharing options...
Fitz Posted October 10, 2016 Share Posted October 10, 2016 Has anyone solved this problem as I have the same thing happened to me. Mine was due to the Rubber seal on the rear window, it was perished round the bottom left part. Had the seal replaced and the small rust spot treated and viola! No more leaks Quote Link to comment Share on other sites More sharing options...
gdog1989 Posted October 10, 2016 Share Posted October 10, 2016 Where the boot stop rubber bits are there is a gap under it that flows the water down the back, it can get blocked with dirt ect, cleaned mine and another members ones out that solved the issue, I use wire coat hanger could take off if they ok or use a compressor.... Quote Link to comment Share on other sites More sharing options...
Ric Posted October 10, 2016 Share Posted October 10, 2016 there are rubber seals for the spoiler too, more likely those are gone or are damaged. Somebody recently bought some with some part numbers on the pics too edit - LH - 76874-14060 RH - 76873-14060 Quote Link to comment Share on other sites More sharing options...
Digsy Posted October 10, 2016 Share Posted October 10, 2016 Mine was due to the Rubber seal on the rear window, it was perished round the bottom left part. Had the seal replaced and the small rust spot treated and viola! No more leaks The lower corners of the rear window are one of the very few areas that Supras are prone to rust. Could be because the drains get blocked, or the window seal itself perishes. Quote Link to comment Share on other sites More sharing options...
rg500 Posted October 24, 2016 Share Posted October 24, 2016 I have removed all rust from the bootlid and treated the rust filled in wiper and sanded all don repainted the bootlid Sealed around the window with silicone sealed the spoiler checked all drainage points still leaking like a sieve. What's left to do getting frustrated now taken a lot of effort on it Where can I get a new seal from also thinking of buying a brand new fibre glass bootlid I've seen on eBay. Quote Link to comment Share on other sites More sharing options...
rg500 Posted October 24, 2016 Share Posted October 24, 2016 Hi Quote Link to comment Share on other sites More sharing options...
SupraLEDrears Posted October 24, 2016 Author Share Posted October 24, 2016 I have removed all rust from the bootlid and treated the rust filled in wiper and sanded all don repainted the bootlid Sealed around the window with silicone sealed the spoiler checked all drainage points still leaking like a sieve. What's left to do getting frustrated now taken a lot of effort on it Where can I get a new seal from also thinking of buying a brand new fibre glass bootlid I've seen on eBay. I solved this problem by buying a new bootlid. Quote Link to comment Share on other sites More sharing options...
rg500 Posted November 1, 2017 Share Posted November 1, 2017 Does anyone know if Toyota still stocks the spoiler seals, if not does anyone know what they are made out of in case I have to make some up. Quote Link to comment Share on other sites More sharing options...
Ric Posted November 2, 2017 Share Posted November 2, 2017 Does anyone know if Toyota still stocks the spoiler seals, if not does anyone know what they are made out of in case I have to make some up. Give them a call to find out. I suppose any butel strip would work as long as it gaskets the hole(s) (3 per side) Quote Link to comment Share on other sites More sharing options...
usman786 Posted May 21, 2018 Share Posted May 21, 2018 I am having the same issue but mine occurred after the car stood still for months. I took the car for car wash and was expecting the boot to be wet but it was dry. I took the hatchback panel off yesterday and poured water on the hatch but no water coming in. Decided to leave it off and keep an eye on it. With the back seats folded I get a perfect view. Quote Link to comment Share on other sites More sharing options...
Scooter Posted May 21, 2018 Share Posted May 21, 2018 I read something the other day which might help, make some lines with chalk along/below possible points of entry, any water running through it will remove the chalk so with some time you can potentially find your entry point? 1 Quote Link to comment Share on other sites More sharing options...
usman786 Posted May 23, 2018 Share Posted May 23, 2018 Can someone please take a photo of their rear wiper nut seal? The round rubber seal you see at the foot of the wiper arm. Mine doesn’t cover the whole nut and wondering should it? The leak is either coming from their or the boot spoiler bolts. I took off the rear spoiler to give it a clean. I have ordered the boot spoiler seals and a new rubber wiper seal from Toyota, they still do these thank god and only have to wait 2 days. Quote Link to comment Share on other sites More sharing options...
trevorc Posted June 22, 2018 Share Posted June 22, 2018 I was advised by Stuart at Lextech to check the fit especially after a respray of the rear light clusters as if this is a little of it can affect the water channelling and thus the problem can occur. Good luck. Quote Link to comment Share on other sites More sharing options...
