LOGIE Posted December 21, 2013 Share Posted December 21, 2013 (edited) OK so in a moment of stupidity today I picked up my prop by one end and the inevitable happened....yep it separated. So do I... A) Pay for it to be rebalanced by a pro? B)Put it back on the car with the rear end on axle stands and see how bad it vibrates and then separate and rotate it 1 splice at a time until it rotates correctly (If this can be done?) Then again I guess this could do more damage to the diff or autobox. There are no markings to indicate where the intermediate and prop were previously coupled. ANY other suggestions welcomed. Bollocks:( Edited December 21, 2013 by LOGIE (see edit history) Quote Link to comment Share on other sites More sharing options...
JamieP Posted December 21, 2013 Share Posted December 21, 2013 Have it balanced, Lee has a guy that does this service. Quote Link to comment Share on other sites More sharing options...
David P Posted December 21, 2013 Share Posted December 21, 2013 The two sections are balanced separately, the position of the splines is for U/J articulation. Take a look at a pic of another and plug it back together in same position. Quote Link to comment Share on other sites More sharing options...
David P Posted December 21, 2013 Share Posted December 21, 2013 (edited) Copy the configuration of the N/A prop at the top, they don't fall in half. The prop sections end yokes are @ 90°. Edited December 21, 2013 by David P (see edit history) Quote Link to comment Share on other sites More sharing options...
LOGIE Posted December 21, 2013 Author Share Posted December 21, 2013 The two sections are balanced separately, the position of the splines is for U/J articulation. Take a look at a pic of another and plug it back together in same position. I did think about that mate but done a search and found this link and posts 13 and 14 got me wondering. http://www.mkivsupra.net/vbb/showthread.php?230869-Drive-shaft-balancing&highlight=balanced+prop Quote Link to comment Share on other sites More sharing options...
David P Posted December 21, 2013 Share Posted December 21, 2013 Now that you've info that puts it into one of two places, you'll most likely find a clue which one it was, yet either will do, grease it up and plug back as pic. Wonder no more. Quote Link to comment Share on other sites More sharing options...
LOGIE Posted December 21, 2013 Author Share Posted December 21, 2013 (edited) Now that you've info that puts it into one of two places, you'll most likely find a clue which one it was, yet either will do, grease it up and plug back as pic. Wonder no more. What pic mate? Edit. Tapabollocks wasnt showing your pic. I see it now. Does that mean I could get it wrong by 180° ? Edited December 21, 2013 by LOGIE (see edit history) Quote Link to comment Share on other sites More sharing options...
David P Posted December 21, 2013 Share Posted December 21, 2013 I answered that question before you asked it? Yes but either will do. Look closely and with only 2 options you'll probably find a clue which way around it was before. Quote Link to comment Share on other sites More sharing options...
TBDevelopments Posted December 22, 2013 Share Posted December 22, 2013 they are balanced as 2 totally separate units. Its common practice to mark and refit as they came apart but its not essential. Remember you can buy each part brand new from Toyota (or used to atleast) these are out the box ready to fit. Toyota would never expect you to have to rebalance everything if you for example were fitting an original front section to a brand new rear section. If it was that critical it would have been made so it can only fit on in one orientation. Just refit it you'll be fine. Tim Quote Link to comment Share on other sites More sharing options...
