A/C not engaging// Odometer cluster causing /!\ master warning light
bluedrag
ok guys i have done my NA-T conversion and have had a link ecu installed, now since having it installed my A/C no longer engages, due to the relay not functioning properly i have established that both sides of the relay have 12v running to them when only one side should, firstly has anyone come across this issue before? and if so where was the power to the wrong side back feeding from?
on a seperate note i have a whole array of warning lights from my ODO cluster that shows up when they are plugged in and the master warning light is on, as soon as i disconnect the ODO cluster plug the master goes out and in theory there is no more short, if someone has a wiring diagram of the interior section or of the whole car that would be fantastic, and before you commenters comment with "use the search Function" i have and have been unable to find what i need hence my reason for asking
any help is much appreciated
cheers
