MattP Posted December 19, 2013 Share Posted December 19, 2013 As the title reads chaps I'm changing my old boot rubbers and as many of you know the screws in the lower half are s***. So my question is this how have people got there old ones out successfully? Link to comment Share on other sites More sharing options...
Suprahitz Posted December 19, 2013 Share Posted December 19, 2013 As the title reads chaps I'm changing my old boot rubbers and as many of you know the screws in the lower half are s***. So my question is this how have people got there old ones out successfully? Hi Matt. I was planning to change my rubbers too but after reading up some where on the forum, you could just remove the top rubbers on the boot lid and placed some washers in between. Boot rattle sorted and cheap and cheerful. Link to comment Share on other sites More sharing options...
David P Posted December 19, 2013 Share Posted December 19, 2013 They're in with Loctite, use heat from a gas blowlamp on the threads and they'll come out. Link to comment Share on other sites More sharing options...
MattP Posted December 19, 2013 Author Share Posted December 19, 2013 This Supra deserves the best all will be changed no cutting corners on this one ..... Link to comment Share on other sites More sharing options...
Suprahitz Posted December 19, 2013 Share Posted December 19, 2013 Or a soldering iron set to high temp should loosen the loctite... Link to comment Share on other sites More sharing options...
Josh42 Posted December 19, 2013 Share Posted December 19, 2013 I used a little Dremel with a cutting disc to cut a slot across the face of the bolt then used a BIG flathead screwdriver to get them out Link to comment Share on other sites More sharing options...
TheTurtleshead Posted December 19, 2013 Share Posted December 19, 2013 This Supra deserves the best all will be changed no cutting corners on this one ..... Cut the old rubber away and you will have access to get onto the head of the screw with mole grips etc... Link to comment Share on other sites More sharing options...
Justin Bieber Posted December 19, 2013 Share Posted December 19, 2013 I used a little Dremel with a cutting disc to cut a slot across the face of the bolt then used a BIG flathead screwdriver to get them out This! Link to comment Share on other sites More sharing options...
Rich.2211 Posted December 19, 2013 Share Posted December 19, 2013 I used a little Dremel with a cutting disc to cut a slot across the face of the bolt then used a BIG flathead screwdriver to get them out I wonder whose idea that was Link to comment Share on other sites More sharing options...
SupraD06 Posted December 19, 2013 Share Posted December 19, 2013 Mine must have been changed at some point then as mine were a doddle. All i did was get a brand new screw driver and hammer it down tight into the screw and with a bit of effort they just came out. Link to comment Share on other sites More sharing options...
Rich.2211 Posted December 19, 2013 Share Posted December 19, 2013 Mine must have been changed at some point then as mine were a doddle. All i did was get a brand new screw driver and hammer it down tight into the screw and with a bit of effort they just came out. Mine were the same on my previous Supra. Took about two minutes, I must of been lucky! Link to comment Share on other sites More sharing options...
skippyboyo1 Posted December 19, 2013 Share Posted December 19, 2013 Blow torched mine mate, have a look in my build thread in my signature and it's in there. Right at the beginning if I recall Link to comment Share on other sites More sharing options...
MattP Posted December 19, 2013 Author Share Posted December 19, 2013 I left this for today and will crack on tomorrow on the plus side all my new focal speakers, srd speaker brackets and whifbitz carbon bonnet dampeners are fitted... A great success Link to comment Share on other sites More sharing options...
Scooter Posted December 19, 2013 Share Posted December 19, 2013 I cut a slot in mine too with a mini hacksaw blade and heated them with a soldering iron. I would cut the slot before attempting undoing with a phillips screwdriver as you'll keep a nice clean slot. You need to be patient if things aren't going well step back and reheat/reassess! Link to comment Share on other sites More sharing options...
trebor69 Posted December 19, 2013 Share Posted December 19, 2013 Cut the rubber away and use a pencil torch to apply some heat to the heads of the screws then use a perfect fitting screwdriver and they come straight out ......the loctite needs heating to free up Link to comment Share on other sites More sharing options...
FOSTA Posted December 19, 2013 Share Posted December 19, 2013 Anyone got the part numbers to the rubbers? If so could you kindly pm me please I might as well replace mine Link to comment Share on other sites More sharing options...
Rich.2211 Posted December 19, 2013 Share Posted December 19, 2013 Anyone got the part numbers to the rubbers? If so could you kindly pm me please I might as well replace mine Not sure on part numbers but here's a link to them being sold by Paul http://www.garagewhifbitz.co.uk/index.php/toyota/supra/interior/toyota-894.html Link to comment Share on other sites More sharing options...
MattP Posted December 20, 2013 Author Share Posted December 20, 2013 I just bought them from from mr Whiffin Link to comment Share on other sites More sharing options...
