How to prep block?
FOSTA
Hey guys,
I've stripped down my engine and I'm just about to clean and paint the block.
But I thought it might be best to hone the bores and clean the top of the block ready for its me head gasket first.
I just wanted people's view on what's the best way to do both jobs?
For the honing I was going to purchase a tool that you plug into your drill and take it easy Going up and down at steady speed and timing how long I take on each bore.
Now for the top of the block ( bottom end ) would I just use a rubbing block with some wet and dry sand paper?
Cheers guys :)
-Bores: Get them measured and glaze busted by someone who knows what they are doing imo! I presume you're not fitting oversize pistons?
-Top: Clean with a flat gasket scraper tool… Check for flatness with a straight edge and feeler gauges. Inspect for corrosion/damage. Determine if it needs a deck.
Then have it dipped and cleaned thoroughly by a machine shop before any painting/re-assembley.
No mate I'm just fitting TT pistons in my GE motor.
I take it its not worth doing yourself then.
Cheers dude.
can dipping be done at home?
ive been cleaning my head with a brass brush on a dremmel with a can of carb cleaner
it does work without damaging/scratching the parts but can dipping be done at home
a friend of mine suggested to leave it to soak in a big tub of petrol and it would be quicker but not sure if thats right?
