jon_dragon Posted December 18, 2013 Share Posted December 18, 2013 Hi NA-T'ers, Im going to start my NA-T project next year but I've got a couple of technical questions before I start. One of which is: Does the oil feed and return have to go to the sump or can I just use an oil filter sandwich plate? Quote Link to comment Share on other sites More sharing options...
Rich.2211 Posted December 18, 2013 Share Posted December 18, 2013 Oil feed from sandwich plate to turbo, oil return from turbo to oil pan Quote Link to comment Share on other sites More sharing options...
Fly Posted December 18, 2013 Share Posted December 18, 2013 or feed from union bolt - requires new union bolt but yes return to sump - - - Updated - - - Edit - Jon join the NA-T comunities section of the club if you havent already it contains quite alot of detail. Quote Link to comment Share on other sites More sharing options...
Al Massey Posted December 18, 2013 Share Posted December 18, 2013 Or buy my unfinished project with a nearly complete ready to go NA-T engine Quote Link to comment Share on other sites More sharing options...
jon_dragon Posted December 18, 2013 Author Share Posted December 18, 2013 Oil feed from sandwich plate to turbo, oil return from turbo to oil pan Do sandwich plates not have 2 unions on? What do you do with the other one? Sorry, is don't know anything about this subject. - - - Updated - - - or feed from union bolt - requires new union bolt but yes return to sump - - - Updated - - - Edit - Jon join the NA-T comunities section of the club if you havent already it contains quite alot of detail. Where's that section? Quote Link to comment Share on other sites More sharing options...
Dazzi Posted December 18, 2013 Share Posted December 18, 2013 Oil pressure from the sandwich plate/union bolt goes to the top of the turbo, then it runs out the bottom of the turbo back into the sump. This is not under pressure, its just gravity letting it drain back. Quote Link to comment Share on other sites More sharing options...
FOSTA Posted December 18, 2013 Share Posted December 18, 2013 There is only one union bolt mate, you will need a Lexus union bolt if you want to take a feed from the bolt. Or you can just use a sandwich plate as you said Quote Link to comment Share on other sites More sharing options...
FOSTA Posted December 18, 2013 Share Posted December 18, 2013 Might be worth alook at this mate: http://www.mkivsupra.net/vbb/showthread.php?279627-FOSTA-S-how-to-fit-a-basic-NA-T-kit&highlight=Fosta%27s+turbo Quote Link to comment Share on other sites More sharing options...
Al Massey Posted December 18, 2013 Share Posted December 18, 2013 You in York Jon? Fairly sure I've seen you about. If you need a hand anytime I'll be in Haxby if you want Quote Link to comment Share on other sites More sharing options...
Rich.2211 Posted December 19, 2013 Share Posted December 19, 2013 Do sandwich plates not have 2 unions on? What do you do with the other one? Sorry, is don't know anything about this subject. No worries at all, I only managed to do my build because of reading up on this forum night after night. Sandwich plates typically have three 1/8th NPT threads in them. Anything you connect to the sandwich plate will have oil pressure (hence the turbo oil feed can be connected to this). Oil from the oil feed line you will have connected goes into the turbo under high pressure but comes out the turbo with very little/no pressure and relies on gravity to return this oil to the oil pan - hence the need for a large internal diameter and smooth oil return line, for ease of flow. The oil return must go to the oil pan as there is no oil pressure there and the least restriction for the oil to return to. If you look at the oil pan you can see the casting where the stock TT oil return bolts up to - this just needs the center drilling through and the two holes tapped ready to bolt your own flange up. I removed my engine & oil pan when drilling mine so I knew it was swarf free.. there are other methods that have been used with success that don't involve pulling the engine but have a read up on them and decide how you want to go about it. Quote Link to comment Share on other sites More sharing options...
Fly Posted December 19, 2013 Share Posted December 19, 2013 jon if you look at the top of the page under the club extras tab you will see comunity, click that then look for a group called club NA-T theres plenty of info on there. - - - Updated - - - http://www.mkiv.co.uk/vbb/group.php?groupid=49 that should take you striaght to it Quote Link to comment Share on other sites More sharing options...
jon_dragon Posted December 19, 2013 Author Share Posted December 19, 2013 You in York Jon? Fairly sure I've seen you about. If you need a hand anytime I'll be in Haxby if you want Dude, I live in haxby! - - - Updated - - - jon if you look at the top of the page under the club extras tab you will see comunity, click that then look for a group called club NA-T theres plenty of info on there. - - - Updated - - - http://www.mkiv.co.uk/vbb/group.php?groupid=49 that should take you striaght to it Thanks buddy, I'll take a look - - - Updated - - - jon if you look at the top of the page under the club extras tab you will see comunity, click that then look for a group called club NA-T theres plenty of info on there. - - - Updated - - - http://www.mkiv.co.uk/vbb/group.php?groupid=49 that should take you striaght to it Thanks buddy, I'll take a look Quote Link to comment Share on other sites More sharing options...
Al Massey Posted December 19, 2013 Share Posted December 19, 2013 Dude, I live in haxby! Seriously?!? Where? I've never seen your car in Haxby! I live down parkland way, ain't had my supe home in nearly a year now. Quote Link to comment Share on other sites More sharing options...
jon_dragon Posted December 21, 2013 Author Share Posted December 21, 2013 Im down West Nooks. Do you also know Jamie who has a white wide arch N/A? He lives nearer to you than I do! Quote Link to comment Share on other sites More sharing options...
jon_dragon Posted December 21, 2013 Author Share Posted December 21, 2013 jon if you look at the top of the page under the club extras tab you will see comunity, click that then look for a group called club NA-T theres plenty of info on there. - - - Updated - - - http://www.mkiv.co.uk/vbb/group.php?groupid=49 that should take you striaght to it Apparently I need to be a member of club NA-T before I can view its contents Quote Link to comment Share on other sites More sharing options...
Al Massey Posted December 21, 2013 Share Posted December 21, 2013 Im down West Nooks. Do you also know Jamie who has a white wide arch N/A? He lives nearer to you than I do! No, didn't know anyone from here was in Haxby. We need a meet up I'm home now if you ever need any help on your car mate Quote Link to comment Share on other sites More sharing options...
jon_dragon Posted December 21, 2013 Author Share Posted December 21, 2013 Im at work currently, at Toyota. Ill probably need help actually doing the NA-T conversion. That wont be a for a while yet though, need to collect all the bits first and the girlfriend is pressing me to move out with her Quote Link to comment Share on other sites More sharing options...
Al Massey Posted December 21, 2013 Share Posted December 21, 2013 Im at work currently, at Toyota. Ill probably need help actually doing the NA-T conversion. That wont be a for a while yet though, need to collect all the bits first and the girlfriend is pressing me to move out with her Fuck her lol The supra is worth more and will always be there for you. (Really hoping my girlfriend doesn't see this as she will kill me) Well I'm available if you need anything bud, may have some spare bits going if you need them Quote Link to comment Share on other sites More sharing options...
jon_dragon Posted December 21, 2013 Author Share Posted December 21, 2013 Hahaha You dont have any NA-T bits spare do you? Quote Link to comment Share on other sites More sharing options...
Al Massey Posted December 21, 2013 Share Posted December 21, 2013 Hahaha You dont have any NA-T bits spare do you? I have a whole engine and shell going.... I may have some bits spare. Will have to wait as I need to bring everything up I to storage as it's all down south at camp Quote Link to comment Share on other sites More sharing options...
