MattP Posted December 17, 2013 Share Posted December 17, 2013 Looking for a set of drilled and grooved uk spec front and rear discs can anyone recommend a set or post up a link please thanks. I have a new set of genuine Toyota discs before anyone says stay stock, the point of changing them is mostly aesthetics more than function Quote Link to comment Share on other sites More sharing options...
Lee P Posted December 17, 2013 Share Posted December 17, 2013 Get the stock ones machined Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted December 17, 2013 Share Posted December 17, 2013 You're going to have to pay more than stock discs to get good quality drilled discs, otherwise they will just crack. Why compromise on brakes just because they look better? Expect more replies in a similar vein. Quote Link to comment Share on other sites More sharing options...
Fizzy T Posted December 17, 2013 Share Posted December 17, 2013 Funnily enough I was going to say what Swampy said but decided not to post it Quote Link to comment Share on other sites More sharing options...
MattP Posted December 17, 2013 Author Share Posted December 17, 2013 You're going to have to pay more than stock discs to get good quality drilled discs, otherwise they will just crack. Why compromise on brakes just because they look better? Expect more replies in a similar vein. People say that but I never had a problem with my ebay specials on my n/a for how the car gets driven and for how little it moves from it's heated garage queen spot cracking shouldn't be a problem Quote Link to comment Share on other sites More sharing options...
MattP Posted December 17, 2013 Author Share Posted December 17, 2013 (edited) Get the stock ones machined Probably end up doing this Edited December 17, 2013 by MattP (see edit history) Quote Link to comment Share on other sites More sharing options...
Dan_Q Posted December 18, 2013 Share Posted December 18, 2013 if you want to sell a full set of new toyota ones to me, i'd be very very interested Quote Link to comment Share on other sites More sharing options...
Mk4Gaz Posted December 18, 2013 Share Posted December 18, 2013 You can buy UK spec pagid front discs from euro car parts, for about £50 per pair You could always have those grooved if you didn't want to risk your current discs Quote Link to comment Share on other sites More sharing options...
Dnk Posted December 18, 2013 Share Posted December 18, 2013 (edited) Get the stock ones machined Is that a good idea, i wouldn't have thought drilling vented discs that weren't designed to have holes in would work and could just weaken the disc. Grooves would probably be okay though. I definitely wouldn't be fitting cheap drilled & grooved discs just because they look better than stock Edited December 18, 2013 by Dnk (see edit history) Quote Link to comment Share on other sites More sharing options...
qwarrior Posted December 18, 2013 Share Posted December 18, 2013 Looking for a set of drilled and grooved uk spec front and rear discs can anyone recommend a set or post up a link please thanks. I have a new set of genuine Toyota discs before anyone says stay stock, the point of changing them is mostly aesthetics more than function I've got UK spec Black Diamond drilled/grooved discs on the front at the moment and they've had track use with EBC yellow pads with no worse performance than stock, but better cooling. I've also had MTec discs on, not as good but a lot cheaper. Still no worse than stock IMO. Quote Link to comment Share on other sites More sharing options...
pedrosixfour Posted December 18, 2013 Share Posted December 18, 2013 Clark Motorsport are very reasonable with DBA slotted disks at the moment. Quote Link to comment Share on other sites More sharing options...
supra steveo Posted December 18, 2013 Share Posted December 18, 2013 dont drill your discs it will only make then weak , I think grooved discs are a better idea if you dont want OEM , think 3G has vanished off the face of the earth now tho Quote Link to comment Share on other sites More sharing options...
MattP Posted December 18, 2013 Author Share Posted December 18, 2013 stick to stock it is Quote Link to comment Share on other sites More sharing options...
BOB B Posted December 19, 2013 Share Posted December 19, 2013 3G do them, I used to have them fitted with no issues, that was with "normal" driving though. Quote Link to comment Share on other sites More sharing options...
MattP Posted December 19, 2013 Author Share Posted December 19, 2013 I had no issues with the drilled and grooved ones I fitted to my N/A but as mentioned the car/cars dont get driven hard so they are purely an cosmetic upgrade Quote Link to comment Share on other sites More sharing options...
