Andrew K Posted December 16, 2013 Share Posted December 16, 2013 I'm thinking about swapping my j-spec sliding rear callipers & discs for a UK rear set up including the discs to compliment the AP Racing big brake kit I'm fitting on the front. Is it just a straight forward swap over regarding the rear brakes? I'm sure I've read recently that when you fit the uk rear callipers etc you have to modify the dirty shield behind, is this so and what exactly needs doing? If they do need modifying can't you just buy the dirty shields that would go on a UK spec car? If so does anybody know the part numbers? Thanks Quote Link to comment Share on other sites More sharing options...
Nic Posted December 16, 2013 Share Posted December 16, 2013 Basically a straight swap, the smaller brakes have a smaller brake disc shield, you'll either need to trim off the lip, remove altogether or fit a bigger dust shield. Quote Link to comment Share on other sites More sharing options...
Andrew K Posted December 16, 2013 Author Share Posted December 16, 2013 Basically a straight swap, the smaller brakes have a smaller brake disc shield, you'll either need to trim off the lip, remove altogether or fit a bigger dust shield. That's what I was hoping to hear thanks Nic if I could I would like to replace the disc shield with the correct item rather than cutting it if I can, do you know the part number for the disc shield that goes with the UK rear setup? Quote Link to comment Share on other sites More sharing options...
pedrosixfour Posted December 16, 2013 Share Posted December 16, 2013 To change the rear dust shields the park brake assembly on both sides will need to be stripped in order to free the park brake cables from their locators, in the dust shields. If you simply remove/cut the offending lip from the shields then the job of swapping rear disks and calipers takes very little time. Quote Link to comment Share on other sites More sharing options...
