tony tt Posted December 15, 2013 Share Posted December 15, 2013 Evening All, I'm currently getting some parts together for my single set up that ill be getting done soon. I just wondered if anyone would be able to hazard a guess as to what kind of power i'd be looking at? At the moment it's a bpu auto and ill be keeping the auto box with a transmission cooler on it. I know the autobox will max out but do you reckon it would get past 550hp with the below? Just a rough estimate if anyone would know...... 60mm non billet turbo kit from whiffin http://www.garagewhifbitz.co.uk/index.php/garage-whifbitz-2107.html 264 Cams Syvecs 850cc Injectors Walbero 450LPH pump FMIC. 3 inch to 4 inch exhaust Thanks. Quote Link to comment Share on other sites More sharing options...
ashbuster Posted December 15, 2013 Share Posted December 15, 2013 isnt the stock box good for around 600hp as long as the torque stays lowish 550- Quote Link to comment Share on other sites More sharing options...
tony tt Posted December 15, 2013 Author Share Posted December 15, 2013 isnt the stock box good for around 600hp as long as the torque stays lowish 550- I think the syvecs can keep the torque at bay slightly but just wondered if it would be close to 600 or i'd be looking at 550 or below. Quote Link to comment Share on other sites More sharing options...
matt k Posted December 15, 2013 Share Posted December 15, 2013 Evening All, I'm currently getting some parts together for my single set up that ill be getting done soon. I just wondered if anyone would be able to hazard a guess as to what kind of power i'd be looking at? At the moment it's a bpu auto and ill be keeping the auto box with a transmission cooler on it. I know the autobox will max out but do you reckon it would get past 550hp with the below? Just a rough estimate if anyone would know...... 60mm non billet turbo kit from whiffin http://www.garagewhifbitz.co.uk/index.php/garage-whifbitz-2107.html 264 Cams Syvecs 850cc Injectors Walbero 450LPH pump FMIC. 3 inch to 4 inch exhaust Thanks. You'll have to wind the boost up, but it's possible to hit 550 bhp with that list. Quote Link to comment Share on other sites More sharing options...
tony tt Posted December 15, 2013 Author Share Posted December 15, 2013 You'll have to wind the boost up, but it's possible to hit 550 bhp with that list. I like boost Quote Link to comment Share on other sites More sharing options...
ashbuster Posted December 15, 2013 Share Posted December 15, 2013 (edited) im sure ive seen around 600 on stock box because thats what im aiming for with a similar setup untill i change to a built box or go manual i have a different turbo but that kit is rated from 500 - 900? so you should max the box out you just need to know whats safe for the box. Edited December 15, 2013 by ashbuster (see edit history) Quote Link to comment Share on other sites More sharing options...
tony tt Posted December 15, 2013 Author Share Posted December 15, 2013 im sure ive seen around 600 on stock box because thats what im aiming for with a similar setup untill i change to a built box or go manual Eventually I'd go built box I'm gettin lazy in my old age. Quote Link to comment Share on other sites More sharing options...
ashbuster Posted December 15, 2013 Share Posted December 15, 2013 lol i know the feeling Quote Link to comment Share on other sites More sharing options...
Graham1984 Posted December 15, 2013 Share Posted December 15, 2013 Didn't Ryan G map the torque to be killed for longer during gear changes on John Baileys 600bhp auto to help save the box? Might be worth doing to help lengthen the gearboxes life after you go single. Quote Link to comment Share on other sites More sharing options...
tony tt Posted December 15, 2013 Author Share Posted December 15, 2013 Didn't Ryan G map the torque to be killed for longer during gear changes on John Baileys 600bhp auto to help save the box? Might be worth doing to help lengthen the gearboxes life after you go single. I'm not sure mate. I know it's all down to the mapping on the day really so it's hard to say. Quote Link to comment Share on other sites More sharing options...
Scott Posted December 15, 2013 Share Posted December 15, 2013 Where you getting the power checked mate? Could wildly vary depending on where you go. I'd say 500-550 would be a fairly safe bet. I don't think you would push up to 600 without the billet, could be wrong though. If it did get you there..... I reckon you'd be pushing the EGTs a bit high. Quote Link to comment Share on other sites More sharing options...
tony tt Posted December 15, 2013 Author Share Posted December 15, 2013 Where you getting the power checked mate? Could wildly vary depending on where you go. I'd say 500-550 would be a fairly safe bet. I don't think you would push up to 600 without the billet, could be wrong though. If it did get you there..... I reckon you'd be pushing the EGTs a bit high. I dont know yet mate where it will be going to get mapped. If it was 550 or slightly higher i'd be well happy with that. Quote Link to comment Share on other sites More sharing options...
Scott Posted December 15, 2013 Share Posted December 15, 2013 I dont know yet mate where it will be going to get mapped. If it was 550 or slightly higher i'd be well happy with that. If you go just about anywhere in Scotland you can play it safe with around 600-650hp I only know of 1 place that gives a conservative power. Saw a BPU Supra run 530bhp a couple of years back, walked away from it on the motorway on the way home Quote Link to comment Share on other sites More sharing options...
Steve Paine Posted December 15, 2013 Share Posted December 15, 2013 I have 500bhp from my stock engine and going through my stock auto box. All mapped by Ryan on an HKS F con pro. Has been running as a daily driver and I don't hang around. To be honest that power level is enough for me! Quote Link to comment Share on other sites More sharing options...
tony tt Posted December 15, 2013 Author Share Posted December 15, 2013 If you go just about anywhere in Scotland you can play it safe with around 600-650hp I only know of 1 place that gives a conservative power. Saw a BPU Supra run 530bhp a couple of years back, walked away from it on the motorway on the way home It wont be mapped in Scotland mate that's a certainty lol - - - Updated - - - I have 500bhp from my stock engine and going through my stock auto box. All mapped by Ryan on an HKS F con pro. Has been running as a daily driver and I don't hang around. To be honest that power level is enough for me! What turbo do you have Steve? Quote Link to comment Share on other sites More sharing options...
LOGIE Posted December 15, 2013 Share Posted December 15, 2013 Eventually I'd go built box I'm gettin lazy in my old age. A tad off topic but id rather have a built autobox than a V160/1. Nothing to do with being lazy I just think its a great auto in stock form so built one would be mega. So Good call. Quote Link to comment Share on other sites More sharing options...
Scott Posted December 15, 2013 Share Posted December 15, 2013 Auto's are for Diesels. Couldn't live with one in a fast petrol car In your shoes I'd just drive it to destruction mate, auto boxes are ten a penny so if it breaks then just stick another in Quote Link to comment Share on other sites More sharing options...
Pig Posted December 15, 2013 Share Posted December 15, 2013 I would say def. sub 600 bhp. Running a 60mm turbo at 1.4 bar you should hopefully be ok. Its difficult to quote numbers as they vary so much dependant on dyno/date - 5yrs ago a reading of 500bhp for bpu was unheard of now its ten a penny. Quote Link to comment Share on other sites More sharing options...
SPG Posted December 15, 2013 Share Posted December 15, 2013 Tony, aslong as its 1rwhp more than Alex, I assume you will be chuffed Quote Link to comment Share on other sites More sharing options...
tony tt Posted December 15, 2013 Author Share Posted December 15, 2013 Tony, aslong as its 1rwhp more than Alex, I assume you will be chuffed Haha I'm not chasing numbers or comparing mate. If it's a nice set up with around 550 or a little more I'll be chuffed. - - - Updated - - - I would say def. sub 600 bhp. Running a 60mm turbo at 1.4 bar you should hopefully be ok. Its difficult to quote numbers as they vary so much dependant on dyno/date - 5yrs ago a reading of 500bhp for bpu was unheard of now its ten a penny. Cheers for input bud. Quote Link to comment Share on other sites More sharing options...
drift_bear Posted December 15, 2013 Share Posted December 15, 2013 Tony, aslong as its 1rwhp more than Alex, I assume you will be chuffed Can if he wants, doesn't bother me tbh Good luck with the build tony, bout time another single appeared up this side of the border that's finished lol Quote Link to comment Share on other sites More sharing options...
tony tt Posted December 15, 2013 Author Share Posted December 15, 2013 I'm not comparing or in the mind set to have a more powerful car than people. That's not the issue here at all. Cheers Alex. Quote Link to comment Share on other sites More sharing options...
thetrashcanman Posted December 15, 2013 Share Posted December 15, 2013 Didn't Ryan G map the torque to be killed for longer during gear changes on John Baileys 600bhp auto to help save the box? Might be worth doing to help lengthen the gearboxes life after you go single. This is correct Ryan killed the torque to protect the autobox, and car was running 607bhp and is was hilariously quick, even more so now John's got the built box on. But even with Ryan reducing the torque from what Chris told me it was still killing the autobox, and would have spat it's guts out eventually so I'd say 500-550 is safe although evidently 600 can be done for a reasonable period of time. Quote Link to comment Share on other sites More sharing options...
drift_bear Posted December 15, 2013 Share Posted December 15, 2013 I'm not comparing or in the mind set to have a more powerful car than people. That's not the issue here at all. Cheers Alex. At least finish yours before scott Quote Link to comment Share on other sites More sharing options...
Graham1984 Posted December 15, 2013 Share Posted December 15, 2013 At least finish yours before scott People will be walking on Mars before Scott finishes. Quote Link to comment Share on other sites More sharing options...
