rob_sri Posted December 15, 2013 Share Posted December 15, 2013 (edited) Hi all, the supra is playing me up recently! heaters have stopped working and now this ! its a 94 NA.. usually it starts first time every time on the first crank and yesterday it was driving fine last night and nothing unusual go to start it this morning it spluttered and just continued to crank.. quick visual check and I could see nothing out of place.. pulled a plug and it was wet.. (with fuel) dried it off and touched it against the block.. got a friend to crank it and it didnt spark.. battery seems fine as it cranks quickly what would be next to check? any suggestions of what it could be? Edited December 15, 2013 by rob_sri (see edit history) Quote Link to comment Share on other sites More sharing options...
Josh42 Posted December 15, 2013 Share Posted December 15, 2013 (edited) HT leads/dizzy cap&rotor arm. Do a drop test mate. If you want me to come round tomorrow I'll do it with you! Edited December 15, 2013 by Josh42 (see edit history) Quote Link to comment Share on other sites More sharing options...
Al Massey Posted December 15, 2013 Share Posted December 15, 2013 Dizzy cap if there is no spark at the plug. Quote Link to comment Share on other sites More sharing options...
rob_sri Posted December 15, 2013 Author Share Posted December 15, 2013 HT leads/dizzy cap&rotor arm. Do a drop test mate. If you want me to come round tomorrow I'll do it with you! Dizzy cap if there is no spark at the plug. thanks luckily I have a spare dizzy assembly.. its really odd that last night it was brilliant, took it for a good run and it was pulling well and this morning nothing!.. i'm at work tomorrow till around 3-4ish drop me a text mate would be great if you're about mate! Quote Link to comment Share on other sites More sharing options...
Dnk Posted December 16, 2013 Share Posted December 16, 2013 Er could it not be the coil, i'd be checking that before you start changing rotor arms, leads or caps. Quote Link to comment Share on other sites More sharing options...
rob_sri Posted December 16, 2013 Author Share Posted December 16, 2013 It started on the first crank this morning and ran perfectly!! How odd!! Quote Link to comment Share on other sites More sharing options...
Dan_Q Posted December 16, 2013 Share Posted December 16, 2013 if its the coil, in my experience they tend to break down and start misfiring under load but run OK at idle etc. I normally work way back from the plugs replacing plugs, leads, cap, arm, igniter, coil. If its just suddenly stopped though i'd check for a loose connection on igniter / coil etc too. Quote Link to comment Share on other sites More sharing options...
rob_sri Posted December 16, 2013 Author Share Posted December 16, 2013 Yeah.. I mean it didn't cut out or anything I turned it off and the next morning wouldn't start.. It may have been a loose connection from the igniter-dizzy but wouldn't start last night as It had flooded.. I pulled all the connections off and gave them a quick spray with WD40 to make sure there was no moisture in there This morning no issues after the plugs had dried out but doesn't explain the no spark.. Il just have keep an eye on it now I suppose! Quote Link to comment Share on other sites More sharing options...
