Knocking from rear over bumps-advice
Josh42
Hi all,
Looking for some advice before I go and spend my life savings;) on all new suspension arms.
For the last week or so I've been experiencing a knocking(clunking) from both sides of the rear of my supra when going over slight imperfections in the road.
I have already replaced the rear anti roll bar drop links, boot rubbers and have set about locating the noise.
I have found some play in the O/S/R wheel when wobbled @ 3-9 o'clock, but none when wobbled from 6-12.
No play on the N/S/R.
The O/S/R wheel is definitely more difficult to rotate than the N/S/R.
I have re torqued the suspension bolts and front subframe to stock figures and I'm now a little at a loss as to what could be next to try?
Struts are KYB Gas-A-just and are around 5 years old having covered only sub 20000 miles.
Springs are Tein S-Tech.
Any ideas welcome.
Edited by Josh42 (see edit history)
Regarding the rotation it could be either the handbrake is dragging
or the caliper is seizing.
Play side to side could well be the top arm bushes.
Does the o/s/r feel any hotter near the caliper/disc ?
I'd pop the wheel off and see if you can move the caliper easily, ease the pads
away from the disc and rotate the wheel to see if its any easier to turn, if not
try backing off the handbrake and check the rotation again
This was my next port of call, so thanks for clarifying this Dunk!
I'll eradicate the wheel bearing from the issue and go from there.
Is it typically the bush or the ball joint that goes?
