Engine Sensor Location
Guest Roger NE
Guest Roger NE
Just need to check the location of these Engine Sensors . . . hope someone can confirm
As you look at the intake side of the block:
1. The one at the top left is the Electric Fan Temperature Switch
2. The one underneath it is the Low Oil Pressure Switch (hidden behind the Aircon Compressor)
3. The one to the right of No. 1 is the Temperature Gauge Sender
Am I correct with these?
Edited by Roger NE (see edit history)
