chris0132 Posted December 13, 2013 Share Posted December 13, 2013 Can someone show me some pictures of where the 3 pipes off the boost controller solenoid go I've got written down where they go but I'm not exactly the smartest pictures always help I found the how to on here but it mentioned something that confused me a little lol, so all I need is a picture of each pipe and where each one goes onto I apologise for my stupidity haha Link to comment Share on other sites More sharing options...
berg Posted December 13, 2013 Share Posted December 13, 2013 Link to comment Share on other sites More sharing options...
chris0132 Posted December 13, 2013 Author Share Posted December 13, 2013 INTERNAL WASTEGATE (SINGLE PORT ACTUATOR) INSTALLATION INSTRUCTIONS Port #1- Connect to an uninterrupted intake manifold pressure source after the throttle body such as a compressor bypass signal line using the 4mm hose. · Do not connect port #1 to the line that operates the fuel pressure regulator unless the supplemental instructions tell you to do so. · This hose should be as short as possible and should not exceed 100cm (3’4”). · Install the 4mm vacuum filter within 10cm(3.9”) of port #1 on the EVC stepping motor. Port #2- Connect to a source of pressurized air such as a turbocharger compressor housing (discharge side) or compressor outlet pipe (before the intercooler) using the 6mm hose. · This hose should be as short as possible and should not exceed 100cm (3’4”). · Install the 6mm vacuum filter within 10cm (3.9”) of port #2 on the EVC stepping motor. Port #3- Connect to the port on the wastegate actuator. · This hose should be as short as possible and should not exceed 100cm Swampy sent me this but I'm still confused lol Link to comment Share on other sites More sharing options...
chris0132 Posted December 13, 2013 Author Share Posted December 13, 2013 So all the people on here with bpu supras and no one has a picture of the boost controller fitted pipe wise can somebody please take one for me if I see it ill be able to fit it easily but the instructions confuse the crap out of Me Link to comment Share on other sites More sharing options...
Chris Wilson Posted December 13, 2013 Share Posted December 13, 2013 Just as berg kindly posted, but the other port to the plenum, engine side of the throttle body. Link to comment Share on other sites More sharing options...
chris0132 Posted December 13, 2013 Author Share Posted December 13, 2013 So I don't have to blank anything off? And what pipes on this diagram is it number 13 and 2 then and then the other I need a t piece on the plenum and that it's then? Link to comment Share on other sites More sharing options...
chris0132 Posted December 14, 2013 Author Share Posted December 14, 2013 http://www.mkivsupra.net/vbb/showthread.php?296003-Boost-Controller-install-(again)&highlight=boost+controller+pipes right almost got it now I think the link for this mentions about blanking the pipes from the vsv one what's the vsv and do I defo need to blank them and any pipe I blank do I need to cap off Link to comment Share on other sites More sharing options...
chris0132 Posted December 14, 2013 Author Share Posted December 14, 2013 So these need blanking and then I just connect it to the last 2 pipes one on the wastegate and one on the turbo pressure one then the other to the plenum Link to comment Share on other sites More sharing options...
Chris Wilson Posted December 14, 2013 Share Posted December 14, 2013 No real need to cap the VSV ports. Cap the spare wastegate capsule port. Cap any unused original hoses. You can T into the original signal line to the recirculation valve for an easy to access plenum air source. Link to comment Share on other sites More sharing options...
