SupraLEDrears Posted December 12, 2013 Share Posted December 12, 2013 Hi guys I'm looking for a 180a alternator that wont break the bank. Saw one for £500 and that's just silly. Any suggestions where I can get one or get it rewound to a higher amperage? Thanks Link to comment Share on other sites More sharing options...
Graham1984 Posted December 12, 2013 Share Posted December 12, 2013 Srd sell uprated alternators, they are traders on here if you didn't know so look them up. Link to comment Share on other sites More sharing options...
Lee P Posted December 12, 2013 Share Posted December 12, 2013 I have 160amp in stock http://www.mkivsupras.net/vbb/showthread.php?292962-SRD-Uprated-Alternators Drop me a pm if you need one Thanks Link to comment Share on other sites More sharing options...
dude Posted December 12, 2013 Share Posted December 12, 2013 Im just getting a 996 one altered so it puts out close to 15v Ill let you know a price when its done for a similar mod, doubt it will cost much. Link to comment Share on other sites More sharing options...
Guest Roger NE Posted December 12, 2013 Share Posted December 12, 2013 Very simple mod to adjust the voltage output, you just alter the Regulator reference. But why on earth would you want to increase the VOLTAGE output?! For a start, lead/acid batteries are supposed to be charged by applying a Constant Voltage of 13.8 Volts - anything greater than that seriously reduces their lifespan But you'll also find your bulbs won't last very long ! Link to comment Share on other sites More sharing options...
dude Posted December 12, 2013 Share Posted December 12, 2013 (edited) Because I am running a Li battery !!!! and if you look on the voltphreaks site the Porsches are pretty much the only car according to them that cannot supply over 14 volts on demand;) Most cars will be between 14 and 14.6V Edited December 12, 2013 by dude (see edit history) Link to comment Share on other sites More sharing options...
Guest Roger NE Posted December 12, 2013 Share Posted December 12, 2013 (edited) Fair enough, but increasing the voltage WILL reduce your bulb life . . . I remember the days BEFORE Alternators, with the crude regulators on Dynamos . . . bulbs didn't last nearly as long I'm looking for a 180a alternator Blimey . . . . that is 2.5 kW !! What on earth do you need that much power for? (You'll also be using LOADS of extra fuel . . . might even strip your Crank Pulley with all that extra load) I also doubt whether a standard one could be re-wound to produce that much power - it would probably need a bigger casing to fit the thicker wire in. Edited December 12, 2013 by Roger NE (see edit history) Link to comment Share on other sites More sharing options...
SupraLEDrears Posted December 12, 2013 Author Share Posted December 12, 2013 Because I need to charge 3 batteries for my car audio system. The current that the sound system will draw will make it even out ha. Link to comment Share on other sites More sharing options...
SupraLEDrears Posted December 12, 2013 Author Share Posted December 12, 2013 I have 160amp in stock http://www.mkivsupras.net/vbb/showthread.php?292962-SRD-Uprated-Alternators Drop me a pm if you need one Thanks Will do if I can't get it rewound but let me know when you have the 200's in stock again please. Im just getting a 996 one altered so it puts out close to 15v Ill let you know a price when its done for a similar mod, doubt it will cost much. Thanks dude! Link to comment Share on other sites More sharing options...
dude Posted December 12, 2013 Share Posted December 12, 2013 Fair enough, but increasing the voltage WILL reduce your bulb life . . . Im mostly LEDS now dude;) Link to comment Share on other sites More sharing options...
Lee P Posted December 12, 2013 Share Posted December 12, 2013 Think people are getting confused here, voltage and Amperage are different things. Increasing the voltage of the alternator is not going to help if your running lots of equipment. If you can fit an adjustable regulator to try and stabilise the voltage that's fine. The OP requires a high Amp alternator. Link to comment Share on other sites More sharing options...
SupraLEDrears Posted December 12, 2013 Author Share Posted December 12, 2013 Think people are getting confused here, voltage and Amperage are different things. Increasing the voltage of the alternator is not going to help if your running lots of equipment. If you can fit an adjustable regulator to try and stabilise the voltage that's fine. The OP requires a high Amp alternator. Correct Link to comment Share on other sites More sharing options...
dude Posted December 12, 2013 Share Posted December 12, 2013 I can get you one made up Link to comment Share on other sites More sharing options...
Guest Roger NE Posted December 12, 2013 Share Posted December 12, 2013 I don't think anyone was getting confused . . . the comments about Current and Voltage were from two different people. But regarding Harry's original point . . . Because I need to charge 3 batteries for my car audio system Yes but what most people don't seem to realise is that whenever the engine is running, it's the ALTERNATOR that powers everything, NOT the battery (or batteries) . . . . that's because the voltage it gives is slightly higher than the battery voltage. But equally, regardless of how much current your Alternator is CAPABLE of giving, a lead/acid battery won't normally draw more than about 15 amps when re-charging itself, even if it's VERY flat. Link to comment Share on other sites More sharing options...
SupraLEDrears Posted December 12, 2013 Author Share Posted December 12, 2013 I don't think anyone was getting confused . . . the comments about Current and Voltage were from two different people. But regarding Harry's original point . . . That's why it's not lead/acid batteries but top secret dry cell deep cycle batteries that weighs about 7 stone each. Yes but what most people don't seem to realise is that whenever the engine is running, it's the ALTERNATOR that powers everything, NOT the battery (or batteries) . . . . that's because the voltage it gives is slightly higher than the battery voltage. But equally, regardless of how much current your Alternator is CAPABLE of giving, a lead/acid battery won't normally draw more than about 15 amps when re-charging itself, even if it's VERY flat. That's why it's not lead/acid batteries but top secret dry cell deep cycle batteries that weighs about 7 stone each. Link to comment Share on other sites More sharing options...
Lee P Posted December 12, 2013 Share Posted December 12, 2013 (edited) Yes I know that but the OP asked about high amperage alternators. I wasnt directing my post at you, I agree with what you have said. I don't think anyone was getting confused . . . the comments about Current and Voltage were from two different people. But regarding Harry's original point . . . Yes but what most people don't seem to realise is that whenever the engine is running, it's the ALTERNATOR that powers everything, NOT the battery (or batteries) . . . . that's because the voltage it gives is slightly higher than the battery voltage. But equally, regardless of how much current your Alternator is CAPABLE of giving, a lead/acid battery won't normally draw more than about 15 amps when re-charging itself, even if it's VERY flat. Edited December 12, 2013 by Lee P (see edit history) Link to comment Share on other sites More sharing options...
SupraP-Z Posted December 23, 2013 Share Posted December 23, 2013 I have an XS power 300amp alternator which will need brackets to be made up to fit to the supra (Not very hard to do) but its currently on my daily driver. Its been bench tested, fitted and approved by Grove Auto Parts. Its never skipped a beat, pm me if you are interested Link to comment Share on other sites More sharing options...
