Delboy52 Posted December 10, 2013 Share Posted December 10, 2013 Has anyone used or know of a good place in the local area to get an unsealed underside done? Link to comment Share on other sites More sharing options...
dude Posted December 10, 2013 Share Posted December 10, 2013 Depends how well you want it done ????? Link to comment Share on other sites More sharing options...
Delboy52 Posted December 10, 2013 Author Share Posted December 10, 2013 On the ramps and power sprayed is the proper way I thought? Link to comment Share on other sites More sharing options...
Guest libra Posted December 10, 2013 Share Posted December 10, 2013 I don't know whereabouts you live (I'm a newby), but I got my MR2 done at Rustmaster. They have two sites, one in Hatfield, the other in Knutsford. It cost me about £450 inc. VAT. The website is http://www.rustmaster.co.uk/ Link to comment Share on other sites More sharing options...
dude Posted December 10, 2013 Share Posted December 10, 2013 So spray over the mud and dead badgers and cover the exhaust and all heat shields etc , waxoil on top or just leave the stonechip/shutz Link to comment Share on other sites More sharing options...
Delboy52 Posted December 10, 2013 Author Share Posted December 10, 2013 Up around Cambridge somewhere would be ideal. Link to comment Share on other sites More sharing options...
Delboy52 Posted December 10, 2013 Author Share Posted December 10, 2013 What is the proper way to do it Dude? Link to comment Share on other sites More sharing options...
dude Posted December 10, 2013 Share Posted December 10, 2013 Up around Cambridge somewhere would be ideal. Less Badgers ??? Link to comment Share on other sites More sharing options...
Delboy52 Posted December 10, 2013 Author Share Posted December 10, 2013 Hehe Less travel and ball ache Link to comment Share on other sites More sharing options...
Guest Roger NE Posted December 10, 2013 Share Posted December 10, 2013 (edited) I've always done mine myself . . . not only is it WAY cheaper, you also know how thorough a job has been done! The main thing is to spend ages doing the prep with a screwdriver and wire brush underneath, removing all loose old underseal (as this can trap water), and removing as much surface rust as possible. Jack the car up and remove each wheel in turn while you do it. Then I use Tetroseal aerosol cans, which are about £7 each for the large ones . . . . 3 cans will do the whole car. Sure, you get filthy (I always put a shower cap on now, as the stuff gets in your hair!) . . . but as I say, at least you know the job has been done thoroughly. If you want to be REALLY thorough, and try and protect INSIDE things, you can squirt something like Waxoyl through the holes in the bottom of the doors, and remove any rubber chassis bungs and do the same. Even better, remove the door cards, interior trims and boot trims and do it that way. Edited December 10, 2013 by Roger NE (see edit history) Link to comment Share on other sites More sharing options...
Rich.2211 Posted December 10, 2013 Share Posted December 10, 2013 I've always done mine myself . . . not only is it WAY cheaper, you also know how thorough a job has been done! The main thing is to spend ages doing the prep with a screwdriver and wire brush underneath, removing all loose old underseal (as this can trap water), and removing as much surface rust as possible. Jack the car up and remove each wheel in turn while you do it. Then I use Tetroseal aerosol cans, which are about £7 each for the large ones . . . . 3 cans will do the whole car. Sure, you get filthy (I always put a shower cap on now, as the stuff gets in your hair!) . . . but as I say, at least you know the job has been done thoroughly. If you want to be REALLY thorough, and try and protect INSIDE things, you can squirt something like Waxoyl through the holes in the bottom of the doors, and remove any rubber chassis bungs and do the same. Even better, remove the door cards, interior trims and boot trims and do it that way. Which Tetroseal products do you use and how long would you say it lasts? Does it need doing every couple of years? Link to comment Share on other sites More sharing options...
Delboy52 Posted December 10, 2013 Author Share Posted December 10, 2013 Sounds like a very thorough job Roger. It's not for my car but a colleagues and am more than certain he'd prefer having someone do it for him. Just trying to find a place local around here. Link to comment Share on other sites More sharing options...
Mugello Posted December 10, 2013 Share Posted December 10, 2013 I did mine myself easy job tbh.... Once i had removed the following; Subframes, fuel tank, suspension, all fuel/brakes lines, bumpers/skirts etc..... Id say its well protected now Link to comment Share on other sites More sharing options...
Dazzi Posted December 10, 2013 Share Posted December 10, 2013 I got my car on a lift and cleaned underneath before doing anything, the car was pretty clean and rust free anyway but I want it to stay that way! All the metal parts i.e the diff, subframe etc I painted with Hammerite direct to rust tin paint. After that I did the rest of the car with Hammerite under-body seal with added waxoyl in a spray can. Make sure you do not get it on anything that gets hot! Very pleased with the result. http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_167975_langId_-1_categoryId_255239 http://www.homebase.co.uk/wcsstore/homebase/images//42089HBO111111M.jpg http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_179695_langId_-1_categoryId_165594 Link to comment Share on other sites More sharing options...
Guest aspire Posted December 10, 2013 Share Posted December 10, 2013 dazzi that is very impressive! how long did it take? Link to comment Share on other sites More sharing options...
Dazzi Posted December 10, 2013 Share Posted December 10, 2013 Thanks. Couple of days. Took my time and did a proper job, even in the chassis holes. Link to comment Share on other sites More sharing options...
Delboy52 Posted December 11, 2013 Author Share Posted December 11, 2013 Very nice work Link to comment Share on other sites More sharing options...
j_jza80 Posted December 11, 2013 Share Posted December 11, 2013 I suspect underseal can cause as many issues as it solves, having worked on many classics. It's probably best to just keep your P&J clean, and not use it during the winter months. Link to comment Share on other sites More sharing options...
Delboy52 Posted December 11, 2013 Author Share Posted December 11, 2013 Why don't all car manufacturers do what Lotus have on the Elise underside? A cover.. Link to comment Share on other sites More sharing options...
j_jza80 Posted December 11, 2013 Share Posted December 11, 2013 Because water doesn't just come from underneath, and covers can create traps. Link to comment Share on other sites More sharing options...
Guest Roger NE Posted December 11, 2013 Share Posted December 11, 2013 Which Tetroseal products do you use and how long would you say it lasts? Does it need doing every couple of years? It's the 500mL aerosol can of Tetroseal Underbody Sealant . . . I like it, because it bonds well, and is very tar-like, so gives good protection (doesn't flake off, like paint can) Personally, I check under the car every year, and scrape/respray any area that needs it (usually only need one can to do this) Link to comment Share on other sites More sharing options...
