Black_Supra Posted December 10, 2013 Share Posted December 10, 2013 Hey guys, i need some advise, got many tipps but everybody tells something different. So, i got 2 044 Bosch Fuel Pumps with Dash 6 feed lines and a Dash 6 return line. I got the OEM breather as you can see and i throw out the active carbon canister. So i got 2 ports and don`t know what to do exactly. Close on of them and put on the other a filter ? Or a back-pressure-valve? Meanings? Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted December 10, 2013 Share Posted December 10, 2013 If you have removed the carbon canister it will be fine, with the CC the tank will run slightly positive pressure anyway, but once the CC is gone the tank is free to breath. Quote Link to comment Share on other sites More sharing options...
