Leaking power steering fluid, but where from?
Cipriani
Ok I have been aware of a leek in the power steering system since I got my supra (9 days ago) and today managed to get under to have a look and determine the area that is actually leaking. As you can see it's been leaking for a while and it's messy down there, so I sprayed brake cleaner and cleaned it up A bit. I think it's a pipe that's leaking but I'm in no way certain. Any ideas? Sorry I know these images may be confusing to look at. imageimageimageimageimageimage
Oh and can anyone tell me what this is?
Gave it a good clean with brake cleaner and left it for about 20 mins. There was a tiny amount of fluid on one of the hoses going into the steering mechanism but it could easily be residual from somewhere higher up. I'm going to investigate the rack further, and what looks like a large drain plug and see where I'm at.
Check the banjo fitting that goes onto the steering rack. It's got a fairly long hard pipe coming off it that the rubber hose goes onto and this can corrode. I had a pinhole in it once and it leaked PAS fluid like a mofo. If you get someone to turn the steering wheel while you watch you shouldbe able to see the fluid coming out under high pressure.
Cheers, will get a good look into this next week. Unfortunately have to go offshore on Thursday but only for 5 days, also looking for a small unit with lighting to let in Lothian if anyone knows of something going?? I'm going to replace all the high pressure hoses so will head down to pirtek soon. I'll do what I can for now on the drive but I really need a new low trolley jack.. Badly
Hope you get it sorted bud, please let us know how much pirtek charge to make one as I'm looking to change mine as well.
Thankyou, Iky.
Guest Roger NE
I have a brand new braided Power Steering Line from Driftmotion in the USA that I'm not going to use now, if you're interested.
It comes complete with right-angled connectors to go straight from the PAS Pump to the rack.
Edited by Roger NE (see edit history)
  • 2 weeks later...
