drift_bear Posted December 6, 2013 Share Posted December 6, 2013 Hey guys done a quick check and came back with what it could be, but wanting to make sure I know exactly what it is so I can fix the problem. I'm trying to sort the issue out from this thread and it's throwing up this code. I've already changed the distributor on it cause it sounded like a problem with that. The error 12 code comes back with The car in question is. 1993 Jspec NA auto Link to comment Share on other sites More sharing options...
Swampy442 Posted December 6, 2013 Share Posted December 6, 2013 Well the cars generally don't lie so Id say if its throwing a 12 then check/change the crank sensor. Link to comment Share on other sites More sharing options...
drift_bear Posted December 6, 2013 Author Share Posted December 6, 2013 Well the cars generally don't lie so Id say if its throwing a 12 then check/change the crank sensor. How easy is it to access/change on an NA supra? Link to comment Share on other sites More sharing options...
Swampy442 Posted December 6, 2013 Share Posted December 6, 2013 Its tucked behind the crank pulley but you should be able to access it from the bottom of the car. - - - Updated - - - Its tucked behind the crank pulley but you should be able to access it from the bottom of the car. Link to comment Share on other sites More sharing options...
drift_bear Posted December 6, 2013 Author Share Posted December 6, 2013 Its tucked behind the crank pulley but you should be able to access it from the bottom of the car. - - - Updated - - - Its tucked behind the crank pulley but you should be able to access it from the bottom of the car. This is going to be a complete pita ain't it?! Lol Link to comment Share on other sites More sharing options...
James Posted December 6, 2013 Share Posted December 6, 2013 Undertrays off (if there are any) and get underneath it. The crank pulley isn't that bad for access to be honest. Link to comment Share on other sites More sharing options...
drift_bear Posted December 6, 2013 Author Share Posted December 6, 2013 Undertrays off (if there are any) and get underneath it. The crank pulley isn't that bad for access to be honest. Just need to try get a sensor now, hopefully if we can get to it then can check the whole sensor and give it a clean. Not used to this NA malarkey Link to comment Share on other sites More sharing options...
Swampy442 Posted December 6, 2013 Share Posted December 6, 2013 The red arrow points to the location Link to comment Share on other sites More sharing options...
drift_bear Posted December 6, 2013 Author Share Posted December 6, 2013 Is the TT and NA crankshaft position sensor the same? Link to comment Share on other sites More sharing options...
Swampy442 Posted December 6, 2013 Share Posted December 6, 2013 Well the GTE part number only points to 1 and 2JZ GTEs so I don't know... Link to comment Share on other sites More sharing options...
drift_bear Posted December 6, 2013 Author Share Posted December 6, 2013 Well the GTE part number only points to 1 and 2JZ GTEs so I don't know... Going by the workshop manual there isn't a crankshaft position sensor (I couldn't see one anyway) for a GE Link to comment Share on other sites More sharing options...
Kirk Posted December 6, 2013 Share Posted December 6, 2013 And you'd be right by saying that. GE's don't have one, it's all done on the distributor gear. Link to comment Share on other sites More sharing options...
drift_bear Posted December 6, 2013 Author Share Posted December 6, 2013 And you'd be right by saying that. GE's don't have one, it's all done on the distributor gear. That's what I thought, knew I wasn't cracking up.... What can I check/fix now then. It had a 1JZ distributor in before so I changed it to a 2JZ one Link to comment Share on other sites More sharing options...
Kirk Posted December 6, 2013 Share Posted December 6, 2013 (edited) http://imageshack.us/a/img27/7969/g843.jpg http://imageshack.us/a/img24/2597/hnh9.jpg http://imageshack.us/a/img41/4139/1ayy.jpg Edited December 6, 2013 by Kirk (see edit history) Link to comment Share on other sites More sharing options...
