Wheel offset et
Pulley
Ok, tried searching
Does anyone have the measurements from hub face of the rear hub and the maximum distance to the coilover/inner most arch
If I were running a 335 rear tyre wot is the minimum (poke ) or -et I can run before my wheel/tyre fouls the inner arch wall/coilover
I can measure over the weekend, just wondered if any of the wide body guys know this offhand
I'm machining a new set of inner rims for my 3 piece splits
To give you an idea… On a stock body I'm running a 315 Tyre, with 11.5 ET50 Wheels. Absolutely cannot go any bigger towards the inner or outer arches.
When I had Nur Arches on the black car, the rears were: 19 x 13J ET 25 also, arches ~50-60mm wider.
Hope this give you an idea. :)
Edited by TheTurtleshead (see edit history)
Cheers, that gives me a good figure for inner clearance, I'll be running veilside wide overfenders so should be fine to cover 335's
