Big jolt at high rpm!?!?!?!?
Guest lewk
Hi guys.
I own a twin turbo auto supra that has most the bpu upgrades apart from hks fcd (which I've been told not to fit) and a boost controller. The rest is all fitted.
I've recently noticed that when the car reaches high rpm and goes to change gear there's a big jolt and almost it seems a loss of power at the same time... Before bursting back into life again.
I would call it a flatspot but it seems asif there is no power at this point and not just limited.
I've got an updated fuel pump on it and it has a 1 bar boost restrictor so I would imagine it's not the fuel system as I'm not putting out crazy amounts of boost and probably only running around 400bhp ish.
Has anyone else experienced this? And does it sound like a gearbox problem?
My gearbox also clunks into drive and reverse very harshly when cold.
Many thanks
Lewis.
It's fuel cut. OP goes BPU but doesn't fit FCD(fuel cut defender) and wonders why he is getting fuel cut!
If it looks like a duck and all that. :D
OP, try to seek out a TRL VFCC and this will solve your problem. Might be worth putting up a wanted thread as they are no longer made. :)
It tends to happen in higher gears at faster speeds...
I have the hks fcd already but not fitted as I've spoke to a number of specialists as I wasn't sure what it was for and they have all said don't fit it because they know of a number of cars that have it and run lean at higher rpm, then things go pop!
A lot of rolling roads also told me they won't touch it if it has one on.
It there another route around this?
- - - Updated - - -
Run lean with the hks fcd that is...
- - - Updated - - -
Click on the blue FCD hyper link mate, explains why a BPU supra needs it. Then dump your specialist and go to someone like Whiftbitz (local to you)
Haha cheers bud! I'm not against using it I just don't know what to do as I've heard lots of different things haha hence the post on here.
Thanks for your help
It does say this on the hyperlink though..
Cons:
Crap FCDs scale the airflow input so that when the stock sensor hits 1.25bar (it's maximum) the ECU gets a shade under 1.0bar. This also has the effect of scaling the ENTIRE airflow signal so the ECU always receives a lower airflow value than the engine is really getting. Messes up the whole fuelling map towards the lean end of the spectrum and is therefore highly not recommended.
Does everyone here have a fcd fitted?
I think the easiest way to explain, it tricks your ECU (car brain) to thinking its ok to boost past the stock pressure of 0.76 therefore it does not trigger the Fuel Cut (The car brains failsafe to protect the car from overboosting, in this case its ok for it to overboost).
Cons:
Note "Crap FCD"
Usually the most common brands used on here are HKS and some other brand, im sure someone will tell you. The other brand is more desired but they are more rare and expensive.
Thanks guys! Apologies for sounding like a complete newbie!
There's too many people around who call themselves specialists haha I don't know who to believe!
Appreciate it.
