gt4tosupra Posted December 2, 2013 Share Posted December 2, 2013 Hi guys. Just wanna know if a supra lsd will go straight into an auto soarer v8? Would it need to be taken from an auto supra? Cheers Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted December 2, 2013 Share Posted December 2, 2013 The unit itself will bolt on, whether the prop flange will need changing is another matter, also the ratio will probably be different. Quote Link to comment Share on other sites More sharing options...
David P Posted December 3, 2013 Share Posted December 3, 2013 (edited) Fit is same as Supra small casing diff and reasonably sure flange is same as N/A. For 'correct' ratio you need an N/A 4.083 A01B. Edited December 3, 2013 by David P (see edit history) Quote Link to comment Share on other sites More sharing options...
gt4tosupra Posted December 3, 2013 Author Share Posted December 3, 2013 Fit is same as Supra small casing diff and reasonably sure flange is same as N/A. For 'correct' ratio you need an N/A 4.083 A01B. Cheers. So that'd be an NA auto diff? Quote Link to comment Share on other sites More sharing options...
David P Posted December 3, 2013 Share Posted December 3, 2013 All N/A diffs are same ratio, all have small prop flange except MT6 which has the larger flange. Quote Link to comment Share on other sites More sharing options...
gt4tosupra Posted December 3, 2013 Author Share Posted December 3, 2013 Cheers. I'll grab one of those then instead of waiting forever for a soarer one Quote Link to comment Share on other sites More sharing options...
David P Posted December 4, 2013 Share Posted December 4, 2013 http://www.mkivsupra.net/vbb/showthread.php?299917-Headlight-subframediffA01B-seats-ODO-suspension-auto-shine-door-speaker-pod Quote Link to comment Share on other sites More sharing options...
gt4tosupra Posted December 4, 2013 Author Share Posted December 4, 2013 http://www.mkivsupra.net/vbb/showthread.php?299917-Headlight-subframediffA01B-seats-ODO-suspension-auto-shine-door-speaker-pod Cheers for the link. Defo an lsd then? Quote Link to comment Share on other sites More sharing options...
James Posted December 4, 2013 Share Posted December 4, 2013 Cheers for the link. Defo an lsd then? The 'B' at the end denotes LSD. If it was an A01A it'd be the 4.083:1 open diff, but the A01B is the 4.083:1 LSD. Quote Link to comment Share on other sites More sharing options...
gt4tosupra Posted December 4, 2013 Author Share Posted December 4, 2013 The 'B' at the end denotes LSD. If it was an A01A it'd be the 4.083:1 open diff, but the A01B is the 4.083:1 LSD. Cheers! Quote Link to comment Share on other sites More sharing options...
