bambisdad Posted December 2, 2013 Share Posted December 2, 2013 I took the car out today for the first time in three weeks and noticed a nasty knocking noise from the nearside rear. It was fine when I put it in the garage last time. Any suggestions as to where I should start looking first? Please help Quote Link to comment Share on other sites More sharing options...
wile e coyote Posted December 2, 2013 Share Posted December 2, 2013 Binding caliper Quote Link to comment Share on other sites More sharing options...
Dan_Q Posted December 2, 2013 Share Posted December 2, 2013 only time I had a clunk from the back so far was a rear ARB droplink. that clunk happened when going over bumps in the road only though. Quote Link to comment Share on other sites More sharing options...
Chris Bailey Posted December 2, 2013 Share Posted December 2, 2013 Wheel bearing? Quote Link to comment Share on other sites More sharing options...
mobius Posted December 2, 2013 Share Posted December 2, 2013 Dodgy shock had this on one of my rears internal failure, no leaks and good compression when it was checked rule out everything else most stuff is visual brakes bushes bearings etc if all OK try the shock I got a used one from Chris Wilson on here either him or Keron cheap 2nd user one will rule that out also. I have had my one on 3 years now no problems. Also check top mount bolts. Quote Link to comment Share on other sites More sharing options...
bambisdad Posted December 3, 2013 Author Share Posted December 3, 2013 I'm hoping its just a failed ARB bush. It is only knocking on the bumps. Will take a proper look tomorrow and see if I can figure it. Quote Link to comment Share on other sites More sharing options...
Fly Posted December 3, 2013 Share Posted December 3, 2013 Someone locked in the boot? Quote Link to comment Share on other sites More sharing options...
Dnk Posted December 3, 2013 Share Posted December 3, 2013 My monies on the shock/damper Quote Link to comment Share on other sites More sharing options...
Robzki Posted December 4, 2013 Share Posted December 4, 2013 Mine started doing this on sunday, as others have said my money is on a shock absorber. Was for me last time anyways. Quote Link to comment Share on other sites More sharing options...
Darren_Whifbitz Posted December 4, 2013 Share Posted December 4, 2013 Shock or arb link are the norm Quote Link to comment Share on other sites More sharing options...
bambisdad Posted December 5, 2013 Author Share Posted December 5, 2013 Thanks guys. Looks like the ARB link has some play in it. Will change these first before considering the shock Quote Link to comment Share on other sites More sharing options...
Guest Budz86 Posted December 5, 2013 Share Posted December 5, 2013 Drop Keron a line, he sells these for less than £20 each iirc. Genuine Toyota is around £70! Quote Link to comment Share on other sites More sharing options...
Dnk Posted December 5, 2013 Share Posted December 5, 2013 Disconnect it and see if the knocking stops Quote Link to comment Share on other sites More sharing options...
Robzki Posted December 5, 2013 Share Posted December 5, 2013 Both times my shocks have gone they have had noticeable oil all over the shocks and springs. It is also a screw your face up knock. Hoping it is arbs for you. Quote Link to comment Share on other sites More sharing options...
