Spec Super Twin Clutch advice needed!
Slutters
Hi guys
Having a few issues with my clutch and need a bit of help please. :)
Basically, i have a Spec Super Twin plate clutch and flywheel combo.
Driving around normally is fine, goes in gear and drives fine.
When you rev higher and are on boost you are unable to change gear easily, you put your foot on the clutch but cannot get it into the next gear as it will not engage.
I have already moved to a 3/4 (19MM) master cylinder and the issue is still present.
I have just brought a 22MM master cylinder and i am hoping this will be the end of my issues, anyone got any advice?
Thanks
Adam
