Linty264 Posted December 1, 2013 Share Posted December 1, 2013 Hi guys, was charging the supra battery reconnected it and tried to start and wouldn't, I've checked all fuses and all are fine. Could this be a starter problem or alarm/immobiliser?Ignition is making the dash lights flash repeatedly when trying to start. It's only be sitting in the garage for about 3-4weeks Link to comment Share on other sites More sharing options...
Guest Roger NE Posted December 1, 2013 Share Posted December 1, 2013 Need more info - what actually happens when you turn the key? Is the engine cranking OK, but just not starting? Or is it not even turning over? (EITHER could be due to your Immobiliser, of course . . . When mine is on it cuts the Starter Motor, the Ignition and the Fuel Pump !) Link to comment Share on other sites More sharing options...
Linty264 Posted December 1, 2013 Author Share Posted December 1, 2013 Seems to be turning over but no attempt at actually starting. I have a clifford concept mk2 tried the blackjack code etc and still no joy it arms and disarms ok too. Link to comment Share on other sites More sharing options...
Tayfun.tugra Posted December 1, 2013 Share Posted December 1, 2013 have you got anything to reset your Immobiliser? What system is it... because it could arm itself when battery is disconnected for a period of time. Link to comment Share on other sites More sharing options...
LOGIE Posted December 1, 2013 Share Posted December 1, 2013 How old is the battery? Do you have another you could try? Even though its been on charge it could be on its way out Link to comment Share on other sites More sharing options...
