Starting problem
Linty264
Hi guys, was charging the supra battery reconnected it and tried to start and wouldn't, I've checked all fuses and all are fine. Could this be a starter problem or alarm/immobiliser?Ignition is making the dash lights flash repeatedly when trying to start. It's only be sitting in the garage for about 3-4weeks
Guest Roger NE
Need more info - what actually happens when you turn the key?
Is the engine cranking OK, but just not starting? Or is it not even turning over?
(EITHER could be due to your Immobiliser, of course . . . When mine is on it cuts the Starter Motor, the Ignition and the Fuel Pump !)
