LOGIE Posted November 30, 2013 Share Posted November 30, 2013 I just about to fire up my TT lump for the first time ever. I HAVE NOT attached the radiator yet so there is no coolant. So how long can I let the engine tick over for SAFELY? Cheers Quote Link to comment Share on other sites More sharing options...
Axl Posted November 30, 2013 Share Posted November 30, 2013 I wouldn't run her for long logie less than 30 seconds if it was me imo good luck with the start up Quote Link to comment Share on other sites More sharing options...
LOGIE Posted November 30, 2013 Author Share Posted November 30, 2013 I bottled it. Ill wait till its daylight and fit the rad in the morning. I haven't fitted the smic either Quote Link to comment Share on other sites More sharing options...
Josh Posted November 30, 2013 Share Posted November 30, 2013 However long it takes to warm up when idling normally. I was worried about mine being started to move it when I took my old radiator out, until I realised that the thermostat doesn't open until it's up to temperature anyhow Quote Link to comment Share on other sites More sharing options...
TBDevelopments Posted November 30, 2013 Share Posted November 30, 2013 yes but there is still coolant in the engine when the thermostat doesn't open to let it circulate. Do you mean first time starting it up after a fresh engine rebuild? If so its important not to let it idle at all for the first 30mins. On all the fresh engines i built i fire them up and hold them at 2500rpm for 20mins to allow it to bed in gently. AT all times getting someone else to go around the car looking for leaks, knocks or anything that shouldn't be. After that i fine tune any ignition timing (doesn't apply to CDI cars) take the car out upto 3000rpm, no more than 0.5bar if you know the fuelling is good. Plenty of overun and engine braking. 50mile mark drop the oil and replace with fresh running in oil. i find the first initial start up and 50miles is the most important as thats when you get the most metal debrit or anything left over that wasn't cleaned properly during the build. You want that stuff out of the engine soon as possible. After that i run till 500miles, drop the oil, new running in upto 1000miles. After that its a quick check over, re-torque head bolts if needed. And fully synthetic oil and off for mapping if its needed. If you let it idle for long periods on first start up it'll glaze the rings and not allow them to bed in properly. this will result in oil consumption and poor sealing from then on. Tim Quote Link to comment Share on other sites More sharing options...
LOGIE Posted November 30, 2013 Author Share Posted November 30, 2013 No rebuild mate, I imported a TT lump from japan with 99,000kms on it. So its well broken in Quote Link to comment Share on other sites More sharing options...
TBDevelopments Posted November 30, 2013 Share Posted November 30, 2013 ah ok. if its not been started up in a while. Put a teaspoon amount of oil down each bore, and crank the engine with EFI fuse out until you get oil pressure built up. Then reinstall fuse and see if it'll spark into life. You'll get a bit of smoke on first start up from the oil in the bores but it means its not done any harm cranking it up after its been sat for a while. Without coolant it'll be fine to fire for a few seconds. Tim Quote Link to comment Share on other sites More sharing options...
LOGIE Posted November 30, 2013 Author Share Posted November 30, 2013 ah ok. if its not been started up in a while. Put a teaspoon amount of oil down each bore, and crank the engine with EFI fuse out until you get oil pressure built up. Then reinstall fuse and see if it'll spark into life. You'll get a bit of smoke on first start up from the oil in the bores but it means its not done any harm cranking it up after its been sat for a while. Without coolant it'll be fine to fire for a few seconds. Tim Thanks mate your talking like a mechanic with a city and guilds certificate, im a f**kwit with a bag of spanners and a laptop. but ill give what you said a try Quote Link to comment Share on other sites More sharing options...
TBDevelopments Posted November 30, 2013 Share Posted November 30, 2013 lol funny you say that, I do what I can. if your unsure on any bits I've said just message me and I'll talk you through it in more detail Tim Quote Link to comment Share on other sites More sharing options...
