Guest Knightrider1980 Posted November 30, 2013 Share Posted November 30, 2013 Well after nearly 4 months of buying a new battery and after not touching my car for nearly 2 weeks due to cold weather and me being on holiday the battery has died on me, tried to boost start the battery but nothing happens, no alarm, no lights light up on the dash except for the red warning light with the exclamation mark is on saying to me that the battery is dead and kaput, good thing that i have a 3 year warranty so i will be making my way to halfords this week to reclaim a new one. Link to comment Share on other sites More sharing options...
Dnk Posted November 30, 2013 Share Posted November 30, 2013 It would pay to check out your car before you fit another, batteries rarely fail so quickly these days Link to comment Share on other sites More sharing options...
Guest Knightrider1980 Posted November 30, 2013 Share Posted November 30, 2013 (edited) It would pay to check out your car before you fit another, batteries rarely fail so quickly these days thats true but i dont drive the car, have not driven her for months and she just sits in the drive way, i only start the car maybe once a week, battery failure is very high probability, ontop of the fact that i boosted the battery twice in the four months when not starting the car for ages. Edited November 30, 2013 by Knightrider1980 (see edit history) Link to comment Share on other sites More sharing options...
Dnk Posted November 30, 2013 Share Posted November 30, 2013 thats true but when i only touch the car once a week and dont drive it, battery failure is very high probability, ontop of the fact that i boosted the battery twice in the four months. I used to leave mine for long periods and the battery was fine, think 6 weeks was around the longest without it being touched and it still fired the car up and worked as it should It would pay you to get a CTEK charger Link to comment Share on other sites More sharing options...
Abz Posted November 30, 2013 Share Posted November 30, 2013 Yep, like Dunk I generally drive mine once a week if that & I have gone 3 - 4 weeks without starting her. Make sure the alarm isn't causing a huge drain or if you have an after market audio amp etc it isn't switched on when you switch the engine off. Halfords are pretty good when replacing it, I had to replace mine as after 2 years it was starting to die, even though the receipt ink had disappeared and you could barely see the code they swapped it. Link to comment Share on other sites More sharing options...
mplavery Posted November 30, 2013 Share Posted November 30, 2013 Mine lasts for about 3 weeks before the battery does go almost flat due to the alarm.. However my battery is a bit of an old girl If I know I'm not going to use it I just disconnect the battery Link to comment Share on other sites More sharing options...
Dnk Posted November 30, 2013 Share Posted November 30, 2013 I think you might find the warranty expires on the replacement battery so check that. The ctek is definitely the way to go and Halfords sell them, approx £50 Link to comment Share on other sites More sharing options...
Guest Knightrider1980 Posted November 30, 2013 Share Posted November 30, 2013 I think you might find the warranty expires on the replacement battery so check that. The ctek is definitely the way to go and Halfords sell them, approx £50 will check it out, i dont know why but even the other supra i had before had the same problem, after 2 weeks or so the battery goes, i do have an alarm system installed which takes the power allot, the cold dont help either. Link to comment Share on other sites More sharing options...
wile e coyote Posted November 30, 2013 Share Posted November 30, 2013 Mine only lasts about 2 weeks before it's too flat to start, but now got a ctech trickle charger thing and no problems now Link to comment Share on other sites More sharing options...
Samurai 20V Posted November 30, 2013 Share Posted November 30, 2013 I am also considering a CTEK. Has anybody any experience with the ZAFIR 45? I think its an older model, got a good deal on it locally.. Link to comment Share on other sites More sharing options...
ashbuster Posted November 30, 2013 Share Posted November 30, 2013 mine also only used to last 2 weeks, batteries always drained Link to comment Share on other sites More sharing options...
supersupra3 Posted November 30, 2013 Share Posted November 30, 2013 2 weeks as well so ctek for me as well Link to comment Share on other sites More sharing options...
