Rear Brake Importance
mk1its
Guys
Bearing in mind that the rear brakes supplement the front brakes, are these brake discs adequate for my UK spec rear calipers:
http://www.ebay.co.uk/itm/TOYOTA-SUPRA-MK4-TURBO-REAR-DRILLED-GROOVED-BRAKE-DISCS-/230589679822?pt=UK_CarsParts_Vehicles_CarParts_SM&fits=Model%3ASupra&hash=item35b03748ce
I'm not trying to cut corners, I just don't see the point of spending more if I don't need to. If only standard brakes are the way to go then I'll purchase them.
All advice appreciated......
Cheers
Mark.
Well they're not designed to oe specs as the advert states as oe aren't drilled or grooved.
I personally don't risk buying unknown ebay parts when it comes to brakes
You'll find the rears do over 40% off the braking too so just not worth it
Thanks DNK, good to know and that's put my mind at rest.......OE it is....
The only discs I thought were worthy of a mention, when doing a rotor upgrade, were the Project Mu, but a little search will show that these were a one time purchase :D, I'm back to OE
I was under the impression that the rear brakes did less than 40% so didn't think they were as important.....40% is a lot so they def need to be FFP(Fit For Purpose).....
The ones you linked to could well be fine but theres no manufacturer listed so for that
reason alone i'd find something else.
Try your local motorfactors and see what they can offer you, a plain non drilled or grooved
disc will be fine and won't suffer cracking like a lot of cheap drilled discs do
Ah indeed, that's reminded me about some EBC front discs I had on a 480bhp 300zx. They cracked through the heat but to be fair, the standard brake setup was no-where near fit for the power I was pushing.....but still....they cracked....
Do 'Halfrauds' sell them? Keron mentioned he had some new OE for £150.....
Well 15yrs is a pretty good testing term. Are you running standard power?
Afraid i sold my supra in April and it now lives in France.
It was a UK spec auto at BPU with around 420 hp for over 10 years, it did a few track days as
well on stock brakes with no issues, the only mods on the brakes were Goodridge braided
lines and i used MOTUL RBF 600 brake fluid
