Crash Bandicoot Posted November 26, 2013 Share Posted November 26, 2013 Before anyone tells me to use the search bar, I have! And found a few useful bits but: I am after step by step instructions on what needs to be removed and unplugged before removal of the engine And anything needed to do the job (special tools) And the procedure of what needs to be re-plugged in and in what order when the engines in the new shell. Any help is greatly appreciated Quote Link to comment Share on other sites More sharing options...
Crash Bandicoot Posted November 26, 2013 Author Share Posted November 26, 2013 I have an NA-t engine so I'm guessing the loom is a NA manual one, and the supra it's going into is an aerotop that started life as an auto, but is now a TT 6 speed. Anything needed to be changed/played with loom wise? Quote Link to comment Share on other sites More sharing options...
ashbuster Posted November 26, 2013 Share Posted November 26, 2013 (edited) have you looked in the manuals bud? http://www.mkivsupra.net/vbb/content.php?51-Repair-Manuals do you plan on keeping the aircon also? if so this can be removed from the engine and left hung in the bay. disconnect the loom from the ecu and the other connecters down there and pull it up through the engine bay by undoing the bolts on the loom where it enters the enginebay you need to disconnected the fuel lines/ power steering lines/ gearbox shifter/ engine earth/ radiator / ect.. its all in the manual but ill try and find a guide for you Edited November 26, 2013 by ashbuster (see edit history) Quote Link to comment Share on other sites More sharing options...
ashbuster Posted November 26, 2013 Share Posted November 26, 2013 here you go mate, na-tt but basically the same . its all common sense really but this will make sure you dont miss anything out http://www.mkivsupra.net/vbb/showthread.php?136136-NA-to-TT-engine-transplant-step-by-step-guide-%28Pic-heavy%29 exactly what you need but if you are still unsure then look in the manuals or ask here Quote Link to comment Share on other sites More sharing options...
Crash Bandicoot Posted November 26, 2013 Author Share Posted November 26, 2013 Cheers chap! I will probably not need the air con as its the aerotop, and even in the British summer it doesn't get hot enough to warrant it. Are the air con units worth much second hand? Any more guides still appreciated Quote Link to comment Share on other sites More sharing options...
ashbuster Posted November 26, 2013 Share Posted November 26, 2013 no worries mate im not too sure how much they are worth second hand but people strip the aircon pulley down and use the plate as a support/brace. ive removed mine too and used the plate so i just chucked everything but i had a leak anyway you wouldnt need the rad part at the front of the car so that could be sold on Quote Link to comment Share on other sites More sharing options...
ashbuster Posted November 26, 2013 Share Posted November 26, 2013 this part here is what you would need to keep Quote Link to comment Share on other sites More sharing options...
Crash Bandicoot Posted November 26, 2013 Author Share Posted November 26, 2013 Ill put it on here with offers, I've got the Tsrm app on my iPhone which is quite handy too should get along fine. Only problem being its winter and I'm doing it on the driveway :/ Quote Link to comment Share on other sites More sharing options...
Crash Bandicoot Posted November 26, 2013 Author Share Posted November 26, 2013 Why do I need to keep that bit? Quote Link to comment Share on other sites More sharing options...
Rich.2211 Posted November 26, 2013 Share Posted November 26, 2013 Why do I need to keep that bit? It supports the power steering pump. - - - Updated - - - this part here is what you would need to keep [ATTACH=CONFIG]177611[/ATTACH] I'm famous Quote Link to comment Share on other sites More sharing options...
ashbuster Posted November 26, 2013 Share Posted November 26, 2013 power steering pump support bud edit beaten to it lol i still havent seen it yet rich ! Quote Link to comment Share on other sites More sharing options...
ashbuster Posted November 26, 2013 Share Posted November 26, 2013 Ill put it on here with offers, I've got the Tsrm app on my iPhone which is quite handy too should get along fine. Only problem being its winter and I'm doing it on the driveway :/ yes tell me about it, my engine is in bits and im putting it together (slowly) really cold outside i was worried that the toyota fipg to seal the sump and pump would be effected doing it in the cold but it seems to have set alright Quote Link to comment Share on other sites More sharing options...
Crash Bandicoot Posted November 26, 2013 Author Share Posted November 26, 2013 Oh, I see. That will be staying then! Haha Quote Link to comment Share on other sites More sharing options...
wile e coyote Posted November 26, 2013 Share Posted November 26, 2013 Slam may have your air on bits inc the rad as husband is shot Quote Link to comment Share on other sites More sharing options...
ashbuster Posted November 26, 2013 Share Posted November 26, 2013 i guess thats autofix on a mobile phone? lol Quote Link to comment Share on other sites More sharing options...
LOGIE Posted November 26, 2013 Share Posted November 26, 2013 http://www.mkivsupra.net/vbb/showthread.php?t=136136 Quote Link to comment Share on other sites More sharing options...
LOGIE Posted November 26, 2013 Share Posted November 26, 2013 Its very detailed with everything you need Quote Link to comment Share on other sites More sharing options...
Crash Bandicoot Posted November 26, 2013 Author Share Posted November 26, 2013 That's the same link posted earlier :/ ha, cheers again tho Quote Link to comment Share on other sites More sharing options...
wile e coyote Posted November 27, 2013 Share Posted November 27, 2013 Lol yeh ha ha Quote Link to comment Share on other sites More sharing options...
LOGIE Posted November 27, 2013 Share Posted November 27, 2013 Opps sorry. Quote Link to comment Share on other sites More sharing options...
Crash Bandicoot Posted November 27, 2013 Author Share Posted November 27, 2013 No need to be sorry, your were just making sure I saw the link, that's all Quote Link to comment Share on other sites More sharing options...
