scott87 Posted November 22, 2013 Share Posted November 22, 2013 I've had a search and cant seem to find the answer for stock 17" wheels. What size tyres can i fit as the rears on my car need replacing..... And is the psi the same all round? 36? Quote Link to comment Share on other sites More sharing options...
scott87 Posted November 22, 2013 Author Share Posted November 22, 2013 Anyone>? Hoping to get these done today..... Quote Link to comment Share on other sites More sharing options...
Iky Posted November 22, 2013 Share Posted November 22, 2013 Is it the factory sizes you're after? front - 235/45/17 rear - 255/40/17 Quote Link to comment Share on other sites More sharing options...
James Posted November 22, 2013 Share Posted November 22, 2013 Did you conduct your search in Russian? I did a search for 'stock tyre sizes' and was presented with a link to this thread: http://mkivsupra.net/vbb/showthread.php?286066-stock-tyre-sizes&highlight=stock+tyre+sizes Reply number 1 indicates that they are 235/45/17 front and 255/40/17 rear. I have run my Supras (varying tyre sizes, types etc.) at 30psi with no issue. Quote Link to comment Share on other sites More sharing options...
scott87 Posted November 22, 2013 Author Share Posted November 22, 2013 Did you conduct your search in Russian? I did a search for 'stock tyre sizes' and was presented with a link to this thread: http://mkivsupra.net/vbb/showthread.php?286066-stock-tyre-sizes&highlight=stock+tyre+sizes Reply number 1 indicates that they are 235/45/17 front and 255/40/17 rear. I have run my Supras (varying tyre sizes, types etc.) at 30psi with no issue. I typed in tyre size 17 :/ Ok so 30psi, i thought they were meant to be much higher than that on stock 17's. would i be ok running 255/45/17 on the rear? Quote Link to comment Share on other sites More sharing options...
Fizzy T Posted November 22, 2013 Share Posted November 22, 2013 I run 32psi on those tyre sizes with no problems. Quote Link to comment Share on other sites More sharing options...
scott87 Posted November 22, 2013 Author Share Posted November 22, 2013 I run 32psi on those tyre sizes with no problems. I was told 36psi..... Anyone know about the slight increase in tyre size? Quote Link to comment Share on other sites More sharing options...
Fizzy T Posted November 22, 2013 Share Posted November 22, 2013 If you open the drivers door and look on the door shut panel there should be a sticker that tells you all the info. Quote Link to comment Share on other sites More sharing options...
Iky Posted November 22, 2013 Share Posted November 22, 2013 I run 36psi for long motorway drives, but 34 for normal round town or spirited driving. Quote Link to comment Share on other sites More sharing options...
scott87 Posted November 22, 2013 Author Share Posted November 22, 2013 If you open the drivers door and look on the door shut panel there should be a sticker that tells you all the info. yer its all in japanese.... im guessing 45profile is no good? Quote Link to comment Share on other sites More sharing options...
Wez Posted November 22, 2013 Share Posted November 22, 2013 I run stock tyre sizes with 36psi up front and 34psi on the rears Quote Link to comment Share on other sites More sharing options...
scott87 Posted November 22, 2013 Author Share Posted November 22, 2013 I run stock tyre sizes with 36psi up front and 34psi on the rears Thanks Im running a bit much then..... Quote Link to comment Share on other sites More sharing options...
Josh Posted November 22, 2013 Share Posted November 22, 2013 I run 34psi front and 32 rear on the stock tyre sizes Quote Link to comment Share on other sites More sharing options...
scott87 Posted November 22, 2013 Author Share Posted November 22, 2013 Any update on if 245 would be suitable? Quote Link to comment Share on other sites More sharing options...
Josh Posted November 22, 2013 Share Posted November 22, 2013 http://www.etyres.co.uk/tyre-size-calculator.htm http://www.1010tires.com/wheeloffsetcalculator.asp Rim width---Min tyre width----Ideal tyre width-------Max tyre width 7.0 inches-----195 mm--------205 or 215 mm-----------225 mm 7.5 inches-----205 mm--------215 or 225 mm-----------235 mm 8.0 inches-----215 mm--------225 or 235 mm-----------245 mm 8.5 inches-----225 mm--------235 or 245 mm-----------255 mm 9,0 inches-----235 mm--------245 or 255 mm-----------265 mm 9.5 inches-----245 mm--------255 or 265 mm-----------275 mm 10.0 inches----255 mm--------265 or 275 mm-----------285 mm 10.5 inches----265 mm--------275 or 285 mm-----------295 mm 11.0 inches----275 mm--------285 or 295 mm-----------305 mm 11.5 inches----285 mm--------295 or 305 mm-----------315 mm 12.0 inches----295 mm--------305 or 315 mm-----------325 mm 12.5 inches----305 mm--------315 or 325 mm-----------335 mm Quote Link to comment Share on other sites More sharing options...
scott87 Posted November 22, 2013 Author Share Posted November 22, 2013 (edited) http://www.etyres.co.uk/tyre-size-calculator.htm http://www.1010tires.com/wheeloffsetcalculator.asp Rim width---Min tyre width----Ideal tyre width-------Max tyre width 7.0 inches-----195 mm--------205 or 215 mm-----------225 mm 7.5 inches-----205 mm--------215 or 225 mm-----------235 mm 8.0 inches-----215 mm--------225 or 235 mm-----------245 mm 8.5 inches-----225 mm--------235 or 245 mm-----------255 mm 9,0 inches-----235 mm--------245 or 255 mm-----------265 mm 9.5 inches-----245 mm--------255 or 265 mm-----------275 mm 10.0 inches----255 mm--------265 or 275 mm-----------285 mm 10.5 inches----265 mm--------275 or 285 mm-----------295 mm 11.0 inches----275 mm--------285 or 295 mm-----------305 mm 11.5 inches----285 mm--------295 or 305 mm-----------315 mm 12.0 inches----295 mm--------305 or 315 mm-----------325 mm 12.5 inches----305 mm--------315 or 325 mm-----------335 mm Im not looking to change the width, increase the profile from 40 to 45. Not out of choice out of value for money when it comes to tyre. *Edit* Sorry the first link says its a 3.93% difference, so im guessing that is a straight no no to do then... But if someone in the no could comment that would be great. on the limit and got a very long drive down south tomorrow and only tyres i can get off shelf near me at a cost suitable are 45 profile. Edited November 22, 2013 by scott87 (see edit history) Quote Link to comment Share on other sites More sharing options...
scott87 Posted December 9, 2013 Author Share Posted December 9, 2013 Ok I still can't find an answer. The tyre place has said that going up to 45 profile on the rear will be fine. Is this correct. There is a hell of a difference in price! If not does anyone have some stock 17inch rear tyres for sale? Quote Link to comment Share on other sites More sharing options...
Littler Posted December 9, 2013 Share Posted December 9, 2013 It would gear the car up going to a 45 profile, your speedo will be out too. I'd also imagine your geo would need setting up again to account the size change. I understand your working to a cost but bare in mind with Supra's tyres wouldn't be a place I'd cut cost Quote Link to comment Share on other sites More sharing options...
scott87 Posted December 9, 2013 Author Share Posted December 9, 2013 It would gear the car up going to a 45 profile, your speedo will be out too. I'd also imagine your geo would need setting up again to account the size change. I understand your working to a cost but bare in mind with Supra's tyres wouldn't be a place I'd cut cost Its purely the fact that i can't get a tyre in the size that is on the car at the moment, unless i buy online bt places are funny about fitting them then. It had 45 on before and i swapped to 40's but these are now nearly dead. So just need some fresh rubber that isn't 300 quid a tire. Quote Link to comment Share on other sites More sharing options...
scott87 Posted December 10, 2013 Author Share Posted December 10, 2013 Ok thanks. Could i use a 265/40/17 rather than a 255/40/17 on the rear? Quote Link to comment Share on other sites More sharing options...
LOGIE Posted December 11, 2013 Share Posted December 11, 2013 Ok thanks. Could i use a 265/40/17 rather than a 255/40/17 on the rear? I curreny have 275 on the rear (stock 17s) with no issues. I got them this way but ill being going with recommend sizes when I get the next set. Quote Link to comment Share on other sites More sharing options...
