Rear Wheel Bearing Drivers side
Jellybean
Hey
just in from the MOT , they said to keep an eye on the rear wheel bearing but replace it if I can, small bit of play
  • Do you need an Alignment if you change the bearing?
  • Automotive bearings or OEM Toyota?
  • Do you need to replace the rear axel shaft too?(drive flanges)
  • Good practice to do both sides at the same time?
http://www.garagewhifbitz.co.uk/index.php/automotive-bearings-3460.html
Can be awkward to hold in the press, as been said the bolts you need to undo can be seized and ive had them in a 20 ton press and still not come out. If its drivers rear and you find you need a top wishbone I have a brand new one half price !!!!!
Nah, just the bearing mate.
As for spurious or OEM the best thing to do is get an idea of price on both.
Toyota Part No. for bearing 90369-43005 (that is bearing only, can't find a kit number, you can ask I suppose & see what is offered)
Blueprint Bearing Kit - ADT38315 - appears to be everything you'd need to do the job.
Personally I've never had any issues with Blueprint parts and I'd prefer them to most other non-genuine offerings.
thanks Damien ; the Automotive Bearing kit (Seals and Bearing is 102 gbp) , Just the OEM Bearing is 216 gbp and OEM seals about 50gbp
Edited by Jellybean (see edit history)
