Crash Bandicoot Posted November 19, 2013 Share Posted November 19, 2013 Removing the dash panels to have resprayed as part of my build thread, does anyone know how to remove the dimmer switch from the panel? Quote Link to comment Share on other sites More sharing options...
Guest aspire Posted November 19, 2013 Share Posted November 19, 2013 pull off knob. you will see a little nut, undo & then pull from back of panel, simples Quote Link to comment Share on other sites More sharing options...
Crash Bandicoot Posted November 19, 2013 Author Share Posted November 19, 2013 That did the trick! Thankyou muchly onward and upward with stripping mine ready for the new build Quote Link to comment Share on other sites More sharing options...
Crash Bandicoot Posted November 19, 2013 Author Share Posted November 19, 2013 A tip for anyone stripping the rubber off the dash panels is put it in a hot wash, I use the one at work but if you haven't got this facility then a bucket of near boiling water should do the trick. Helping to loosen it. Then use a flat scraper to remove the rubber followed by some scotch pad to remove the existing glue half hour a panel so far! Quote Link to comment Share on other sites More sharing options...
