Window mech question.
Shane
For the second time since owning Supras I closed the door today, heard a twang and my window went down on it's own. Had a quick look and again the white clip has fallen to pieces and the cable come off. Are both sides the same, or are they handed? I am guessing so.
both sides are different mate they are marked rh and lh IIRC
I thought as much
Window Twang key maybe? ;)
Hope you got it propped up O.K.
Yes I used a ratchet strap, threaded one end between the glass and the door with that end hooked onto the glass fram and the other strap end onto the door. Worked a treat, as I tightened up the strap the window went up.
Regulators are handed but you might be able to swap some bits over.
I wondered that, there is a guy selling a box of window bits on ebay and thought I may be able to make something up with what I already had. But in the meantime, I have bought a complete working one from another member.
