Error code 42
Guest geth792
Guest geth792
Need help on error code 42!! Been told it could be a speed sensor which is £200!!! Plus the supra is idling terrible and missing loads could this be because of code 42????? Help
42 is indeed the speed sensor circuit system warning. I'd first have a look at the wiring to the speed sensor and also in the ECU footwell area to make sure there's no break in it. The wire is often tapped into for the speedo reading and other things such as a de-limiter so a faulty connection is highly likely. I very much doubt it's the sensor itself, I've never heard of one failing.
Edit, oh and click the link "error code", I think the 3rd or 4th attachment shows the possible areas to look at.
