Kaan W Posted January 10, 2014 Share Posted January 10, 2014 Jellybean said: You can get 25mm and 30mm bolt on Spacers I know, I said 20mm is the smallest bolt on Well... Safely any thinner and the amount of material to the spacer bolted on would be dangerous imo. Quote Link to comment Share on other sites More sharing options...
Jellybean Posted January 10, 2014 Author Share Posted January 10, 2014 Kaan W said: I know, I said 20mm is the smallest bolt on Well... Safely any thinner and the amount of material to the spacer bolted on would be dangerous imo. Sorry I mis-read, you can go as low as 10mm bolt ons http://www.evasivemotorsports.com/mm5/merchant.mvc?Screen=PROD&Product_Code=KICS-5110W1 Quote Link to comment Share on other sites More sharing options...
Kaan W Posted January 10, 2014 Share Posted January 10, 2014 Jellybean said: Sorry I mis-read, you can go as low as 10mm bolt ons http://www.evasivemotorsports.com/mm5/merchant.mvc?Screen=PROD&Product_Code=KICS-5110W1 Safely? I wouldn't trust them, just look how thin the material is where it bolts to the hub. They're not even hub centric so the entire load is on bolts. Just by opinion anyway Quote Link to comment Share on other sites More sharing options...
Jellybean Posted January 10, 2014 Author Share Posted January 10, 2014 Kaan W said: Safely? I wouldn't trust them, just look how thin the material is where it bolts to the hub. They're not even hub centric so the entire load is on bolts. Just by opinion anyway You get hub centric rings with them As far as I know, they are the only Japanese certified spacer for the Shaken (Japan's MOT equivalent) Quote Link to comment Share on other sites More sharing options...
Kaan W Posted January 10, 2014 Share Posted January 10, 2014 Jellybean said: You get hub centric rings with them As far as I know, they are the only Japanese certified spacer for the Shaken (Japan's MOT equivalent) http://d5otzd52uv6zz.cloudfront.net/group-bea48bbb-5f5d-496d-b61b-966e8f4fd0ee-420.jpg It's your car dude not mine, unless your running crazy power they should be fine Quote Link to comment Share on other sites More sharing options...
Jellybean Posted January 10, 2014 Author Share Posted January 10, 2014 Kaan W said: It's your car dude not mine, unless your running crazy power they should be fine What could possilbe go wrong? Quote Link to comment Share on other sites More sharing options...
Kaan W Posted January 10, 2014 Share Posted January 10, 2014 Jellybean said: What could possilbe go wrong? Nothing I hope As said they should be fine. They wouldn't sell them otherwise I'm gunno be running a few more horses and maybe doing drag runs so I wouldnt use them for my car. Quote Link to comment Share on other sites More sharing options...
