mac79 Posted November 15, 2013 Share Posted November 15, 2013 (edited) I have just had my exhaust fitted with a single pipe from the first cat back. It sounds great but i feel down on performance. I seem to have to push the car hard to get it to boost, the gauge is reading right so do i need to fit a more free flowing air filter and give the ecu a reset? I also fitted a HKS SSQV but the gauge is reading -0.8 at tick over and 0.8 on boost so i dont think there is any leaks with that. Edited November 15, 2013 by mac79 (see edit history) Link to comment Share on other sites More sharing options...
Josh Posted November 15, 2013 Share Posted November 15, 2013 Since putting the second decat and restrictor ring back in, I've noticed it starts making positive boost at higher revs and under higher load than with just the second cat in. Maybe it doesn't, but it does seem to have made a difference. Maybe due to the difference in the restriction between the second cat and when the restrictor ring is fitted with the decat. To add, I'm also running a Nur Spec R Link to comment Share on other sites More sharing options...
mac79 Posted November 15, 2013 Author Share Posted November 15, 2013 When it was first done the revs were more responsive and it did feel quicker. So maybe get a restrictor ring fitted? Link to comment Share on other sites More sharing options...
Josh Posted November 15, 2013 Share Posted November 15, 2013 When it was first done the revs were more responsive and it did feel quicker. So maybe get a restrictor ring fitted? Are you still running both cats? If the boost is staying at 0.8bar, then there shouldn't really be any change AFAIK. You'll only need the restrictor ring if you remove both cats. Link to comment Share on other sites More sharing options...
mac79 Posted November 15, 2013 Author Share Posted November 15, 2013 I have left the first cat in. The pipe is 3" back from that to the backbox. Link to comment Share on other sites More sharing options...
Josh Posted November 15, 2013 Share Posted November 15, 2013 I have left the first cat in. The pipe is 3" back from that to the backbox. That's the most restrictive one, so it shouldn't really have made a difference changing the exhaust. You'll need someone more knowledgable than me now, as it may be to do with the BOV. Link to comment Share on other sites More sharing options...
mac79 Posted November 15, 2013 Author Share Posted November 15, 2013 Thanks for trying to help. Link to comment Share on other sites More sharing options...
TBDevelopments Posted November 16, 2013 Share Posted November 16, 2013 reset the ecu and take it for a drive, see if you get any improvement. Had this a few times with the Mr2's and the ecu's not liking the sudden change in the way the engine breaths. Goes against all logic or how it should work. But lets the ecu go back to its basics without any knock correction its had over the years and learns from a fresh Worth a try. Tim Link to comment Share on other sites More sharing options...
Pipedreams Posted November 17, 2013 Share Posted November 17, 2013 Maybe it´s just the lower back dyno foolin you With a free flowing exhaust you will build boost earlier and get a smoother powerband without a real kick in the back but you are moving faster earlier. Link to comment Share on other sites More sharing options...
mac79 Posted November 18, 2013 Author Share Posted November 18, 2013 reset the ecu and take it for a drive, see if you get any improvement. Had this a few times with the Mr2's and the ecu's not liking the sudden change in the way the engine breaths. Goes against all logic or how it should work. But lets the ecu go back to its basics without any knock correction its had over the years and learns from a fresh Worth a try. Tim Do you think its worth dropping a blitz panel filter in as well before giving the reset? We need to go out for a run at some point as well! Link to comment Share on other sites More sharing options...
mac79 Posted November 18, 2013 Author Share Posted November 18, 2013 Maybe it´s just the lower back dyno foolin you With a free flowing exhaust you will build boost earlier and get a smoother powerband without a real kick in the back but you are moving faster earlier. That does make sense it might just be that. Link to comment Share on other sites More sharing options...
TBDevelopments Posted November 18, 2013 Share Posted November 18, 2013 well ecu reset is only a 2min job anyway. your only down the road from me aren't you? you should pop over one night your always welcome Tim Link to comment Share on other sites More sharing options...
mac79 Posted November 18, 2013 Author Share Posted November 18, 2013 I take it you are still working late down the unit? I will pop over. I made need your bracket making skills to locate my bov. Link to comment Share on other sites More sharing options...
TBDevelopments Posted November 18, 2013 Share Posted November 18, 2013 depends on the day, usually till 6pm or tomorrow i'll be there late as have a rush job for a guy. Link to comment Share on other sites More sharing options...
