IACV with new intake manifold
berg
I will be using a billet q45 throttle body on my new intake manifold (mines na-t by the way) and i have got hold of a TT IACV to use
This will be fitted to the bottom of the manifold
I will blank off the 2 waters outlets but im not sure what to do with the other one
Ive been told this will need to be hooked up to my intercooler pipe just before the butterfly, which makes sense, but ive seen some people using a filter on it?
Whats the best method and how does using a filter on the end actually work?
Sweet easy job then, seems so much confusion about iacv's when reading up about these intake manifolds, but really its seems forward
Just got to get one of those greddy tps adaptors now to use my tps, expensive aint they lol
Why do you need an adaptor for the tps ?
If you using Syvecs then just use the tps that came with the TB, if not I have the TPS adapter in stock
Stock tps doesn't fit the q45 throttle body but the little adaptor plate allows it to.
Cheers Lee ill be in touch about ordering one
