mclarenross Posted November 11, 2013 Share Posted November 11, 2013 So I've lost the locking wheel nut on my supra and I've just bought some new alloys and I'm desperate to fit them. Anyone know of a clever way to get them off? I've tried those laser removal things from halfords, but they didn't work. Is there any other way to get them off?? Tricks of the trade ... please pm if you don't want to broadcast to the world the answer... Link to comment Share on other sites More sharing options...
naybad Posted November 11, 2013 Share Posted November 11, 2013 If you can get a 12 point socket that is smaller than the locking nut just hammer it on this works most of the time but make sure you get the socket on as far as you can. Link to comment Share on other sites More sharing options...
Iky Posted November 11, 2013 Share Posted November 11, 2013 What type of locking nuts are they? If they are the ones with a spinning collar then it's going to be a bitch of a job. Photos please.... Link to comment Share on other sites More sharing options...
listy Posted November 11, 2013 Share Posted November 11, 2013 New alloys at this time of year? Madness I say, MADNESS!!! Link to comment Share on other sites More sharing options...
mattdavies Posted November 11, 2013 Share Posted November 11, 2013 if they are Mcguard and you have the original box they can send you a new key to fit them Link to comment Share on other sites More sharing options...
safcdixon Posted November 11, 2013 Share Posted November 11, 2013 Weld a nut onto the centres thats what i did on my bro in laws motor a few years back, or as above whack a nut over the top, if they are the spinning collar type then use a small screwdriver/chisel to break off the collar first Link to comment Share on other sites More sharing options...
Benjy Posted November 11, 2013 Share Posted November 11, 2013 Buy the proper nut removal tool. Most garages should have one but don't be suprised if it costs £200! Link to comment Share on other sites More sharing options...
mclarenross Posted November 11, 2013 Author Share Posted November 11, 2013 Its one of these types.... it has 8 raised bars around it, I've tried ordering other similar ones off Ebay, but non fit... I'm not confident welding, want to try all other options before getting the welder out and bodging it... Link to comment Share on other sites More sharing options...
Iky Posted November 11, 2013 Share Posted November 11, 2013 I would find a 1/2" drive socket just a tad smaller to smack over it. That's an easy one. to undo. you might need to grid down the outside to get it to fit into the bore. Link to comment Share on other sites More sharing options...
Iky Posted November 11, 2013 Share Posted November 11, 2013 I would find a 1/2" drive socket just a tad smaller to smack over it. That's an easy one. to undo. you might need to grid down the outside to get it to fit into the bore. I discovered (for me) the trick to the laser reverse screw types is to have them at a slight angle. They wont catch if you screw them dead on. Then use a small strong bar carefully. Link to comment Share on other sites More sharing options...
Mugello Posted November 11, 2013 Share Posted November 11, 2013 I just got a 12 sided socket that was slightly smaller and hammered it on. Worked a treat. However as above you can also weld a socket onto the nut Link to comment Share on other sites More sharing options...
mclarenross Posted November 11, 2013 Author Share Posted November 11, 2013 thanks guys, will try the above techniques tonight! Link to comment Share on other sites More sharing options...
scott87 Posted November 11, 2013 Share Posted November 11, 2013 Buy some irwins, will do the job..... Link to comment Share on other sites More sharing options...
mclarenross Posted November 11, 2013 Author Share Posted November 11, 2013 yeah, thats last chance saloon, I dont really want to spend c£45 just to get my wheel nuts off.... Link to comment Share on other sites More sharing options...
scott87 Posted November 11, 2013 Share Posted November 11, 2013 yeah, thats last chance saloon, I dont really want to spend c£45 just to get my wheel nuts off.... :-o my irwins were like 11quid..... Link to comment Share on other sites More sharing options...
mclarenross Posted November 11, 2013 Author Share Posted November 11, 2013 Irwin's ordered. £18 Link to comment Share on other sites More sharing options...
Guest bigggie25 Posted November 13, 2013 Share Posted November 13, 2013 Last resort!! We do weld on 19mm hex nut as a last resort at very high amperage.!!!works always. just try not to damage the paint on your wheels. Irwin's are ok but not always up to the job!!! Link to comment Share on other sites More sharing options...
trebor69 Posted November 13, 2013 Share Posted November 13, 2013 I lost mine a while ago and just hammered a socket over the top and removed them ...all 4 , same socket......just make sure your other 4 wheel nuts are tight which will ease the pressure on the locking one ......simples. Link to comment Share on other sites More sharing options...
