ABS wire and handbrake cable removal
Guest Budz86
Just wondering if these can be disconnected at the hub or is it best to take them off at 'source'? Replacing a rear wheel bearing so whole hub needs to come off :)
Thanks in advance!
There`s a connector for the abs behind the back seats, or remove the sensor from the hub if its not seized in, remove the handbrake cable from the yoke under the car, undo the 10mm bolt from the clamp then the end from the yoke, make sure the handbrake is off btw, but chock the wheels 1st.
Thanks mate, I took the whole handbrake cable off last time I did this but wondered if there was a quicker way. As for the ABS sensor, I've undone the bolt and given it a gentle pry with a flathead but feels stuck. Guess the whole wire is coming out!
