Guest DVS2JZ Posted November 10, 2013 Share Posted November 10, 2013 hey fellow supra peoples i have a few questions to ask... 1. Anyone got a step by step guide on how to install an a/f gauge? 2. Anyone recommend a particular kit that comes with everything to install an a/f gauge inc. the gauge? 3. is there a 2step limiter i can put on my 2jz-ge?, if so can you recommend one? Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted November 10, 2013 Share Posted November 10, 2013 Theres no point fitting an afr gauge on a GE (unless you're NA/T) so thats 1 and 2 taken car of, and a 2 step limiter, is that a Bee R? Quote Link to comment Share on other sites More sharing options...
Fly Posted November 10, 2013 Share Posted November 10, 2013 Welcome to the club. I would suggest the innovate range. Their wideband afr gauge comes with sensor and also has data logging capability. The kit comes with step by step instructions. As for the limiter no idea sorry Quote Link to comment Share on other sites More sharing options...
Guest DVS2JZ Posted November 12, 2013 Share Posted November 12, 2013 Welcome to the club. I would suggest the innovate range. Their wideband afr gauge comes with sensor and also has data logging capability. The kit comes with step by step instructions. As for the limiter no idea sorry thanks yeah its partly a style thing but i just like to know what my car is doing Quote Link to comment Share on other sites More sharing options...
Guest Roger NE Posted November 12, 2013 Share Posted November 12, 2013 (edited) i just like to know what my car is doingI know what you mean . . . I'm a Mk3 Supra owner (on here as I'm fitting a 2JZ-GE) . . . but I'm amazed the Mk4 doesn't have an Oil Pressure gauge or Voltmeter as standard on the dash, like the Mk3! Edited November 12, 2013 by Roger NE (see edit history) Quote Link to comment Share on other sites More sharing options...
Guest DVS2JZ Posted November 12, 2013 Share Posted November 12, 2013 I know what you mean . . . I'm a Mk3 Supra owner (on here as I'm fitting a 2JZ-GE) . . . but I'm amazed the Mk4 doesn't have an Oil Pressure gauge or Voltmeter as standard on the dash, like the Mk3! i got a volt gauge taken care of, it linked to the bank of batteries for my stereo in the back, they are easy to do especially since i use a relay to turn my amps, gauges etc on - - - Updated - - - Theres no point fitting an afr gauge on a GE (unless you're NA/T) so thats 1 and 2 taken car of, and a 2 step limiter, is that a Bee R? as to wether its pointless is besides the point... and yeah like a bee r Quote Link to comment Share on other sites More sharing options...
Graham1984 Posted November 12, 2013 Share Posted November 12, 2013 I have an annoying voltmeter and afr gauge on my A frame trim that the previous owner put in (apparently he was going to NA-T it) now as annoying as it is as the afr gauge is not even plumbed in so I am running extremely lean the voltmeter saved my arse the other month when my alternator started to go tits up. Quote Link to comment Share on other sites More sharing options...
David P Posted November 12, 2013 Share Posted November 12, 2013 the voltmeter saved my arse when my alternator started to go tits up. Quote Link to comment Share on other sites More sharing options...
Graham1984 Posted November 12, 2013 Share Posted November 12, 2013 I meant more along the lines I didn't head up the motorway to go out Quote Link to comment Share on other sites More sharing options...
David P Posted November 12, 2013 Share Posted November 12, 2013 Sounded like you'd found a gay auto-electrician with a tin of Swarfega. Quote Link to comment Share on other sites More sharing options...
Shane Posted November 12, 2013 Share Posted November 12, 2013 hey fellow supra peoples i have a few questions to ask... 1. Anyone got a step by step guide on how to install an a/f gauge? 2. Anyone recommend a particular kit that comes with everything to install an a/f gauge inc. the gauge? 3. is there a 2step limiter i can put on my 2jz-ge?, if so can you recommend one? If you flip the cover on your diagnostic port, the ox1 and ox2 pins are from the 2 o2 sensors used on the ge which if you are fitting a simple "am I lean or not" narrow band will do. Otherwise for a wideband you will need to get a boss welded in somewhere for the wideband sensor. Suprakeith has a bee r fitted, there was a thread about it recently and it went down well with a few members if you do a search I am sure you can find it, he may be able to help you re fitting tips. Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted November 12, 2013 Share Posted November 12, 2013 If you just want a decorative gauge then just fit a narrow band lambda gauge, it wont tell you anything useful, but it will look the part, however anyone who knows engines will probably laugh, if you don't trust the std ECU or want to tune then fit a wide-band lambda setup, if you want some very good data logging capabilities and software then go for one of the Innovate Motorsport range. Quote Link to comment Share on other sites More sharing options...
Paul-90 Posted November 12, 2013 Share Posted November 12, 2013 As for the 2 step limiter i have an omex limiter in my na with launch control. Very easy to fit and the launch control is wired to a button on my gear stick. Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted November 12, 2013 Share Posted November 12, 2013 If you just want a decorative gauge then just fit a narrow band lambda gauge, it wont tell you anything useful, but it will look the part, however anyone who knows engines will probably laugh as to wether its pointless is besides the point... and yeah like a bee r See above lol Quote Link to comment Share on other sites More sharing options...
scott87 Posted November 12, 2013 Share Posted November 12, 2013 As for the 2 step limiter i have an omex limiter in my na with launch control. Very easy to fit and the launch control is wired to a button on my gear stick. What is this? Explain more please.... Quote Link to comment Share on other sites More sharing options...
Paul-90 Posted November 23, 2013 Share Posted November 23, 2013 What is this? Explain more please.... The omex limiter is wired into your coil just. I think its called a spark interrupter. Mine has launch control which is a second lower limiter that is controlled by a button. Both limiters are fully adjustable and i have mine set to 100 rpm below the standard limiter and the launch control is set to around 5000rpm i think. Brand new the omex limiter with launch control is around £120. Quote Link to comment Share on other sites More sharing options...
Guest MK-4 Posted June 30, 2016 Share Posted June 30, 2016 hy paul i need your help how you connect the omex rev limiter ?? Quote Link to comment Share on other sites More sharing options...
