costas1 Posted November 9, 2013 Share Posted November 9, 2013 hi guys..i was just wondering if there is way to switch from sequentiall to parallel mode from inside the car with a switch? like installing an electrovalve or something..has anyone try it? how much does it cost? Quote Link to comment Share on other sites More sharing options...
heckler Posted November 9, 2013 Share Posted November 9, 2013 follow my guide... http://www.internetwork.org.uk/electrical/ettc/ettc.htm Quote Link to comment Share on other sites More sharing options...
costas1 Posted November 10, 2013 Author Share Posted November 10, 2013 thx a lot mate and most probably will go with the first method (easy one)..all understood but it doesn't say what to do with the valve..connect the 6 wires to the switch and you take them to the valve..how do you connect them there? Quote Link to comment Share on other sites More sharing options...
heckler Posted November 10, 2013 Share Posted November 10, 2013 yes it does, cut the wire and join the wires from the to ecu wires " Follow ONE wire at a time the wire away from the ECU 6 - 8" and then cut, then do the following This bit is important! Take pin 39 FROM THE ECU and connect it to the top left contact on the rocker switch by use of the bullet connectors" foe each wire Quote Link to comment Share on other sites More sharing options...
costas1 Posted November 11, 2013 Author Share Posted November 11, 2013 ok... i thought the first method was saying that you do not mess at all with the ecu.. thought that this was the second method.. thx mate Quote Link to comment Share on other sites More sharing options...
