Getting a little toasty...
Big Supes
Noticed after pulling into a services that steam was coming from the bonnet. Had a look and the plastic lid from the expansion tank had popped off. There wasn't much water in the bottle so I filled it up and we got back on the road.
Everything seemed ok at the next stop... no steam, but who knows what the engine temp was with the stock dash gauge?!
Had a little wide open time on the way home and could hear the radiator boiling/bubbling after killing the engine. She's definitely getting a tad warm.
BTW, I had a look under the car after refilling the expansion tank and couldn't see any leaks.
Going to take it off the road until I've narrowed down the problem. Thinking it could be a worn water pump?
Any suggestions welcome. :)
Edited by Big Supes (see edit history)
What rad cap is on it ? sounds very much like thats letting the pressure out the
system too easily below the required running pressure hence it popped the expansion
tank cap off.
Unless you know its not very old i'd replace that and re fill the expansion tank to the max
mark, fill up the rad and bleed out any air, if there's air in the system the coolant will boil
which is pretty much what you have happening
Use Ethylene glycol premix, not tap water
I doubt its the water pump
Thanks, Dunk. I'll give that a try. I'm presuming the tank cap is oe, but will double check when it stops raining.
For what they cost it would be the first thing to try, obviously check for other
problems, heater matrix hoses are a common place to fail, between the engine
and bulkhead, also check the footwell isnt damp as the matrix are also getting a bit prone
to leaking too.
Make sure you get a stock rad cap, best from Toyota at the correct bar rating
Rad cap ordered... Oddly Toyota said they don't stock a separate cap for the UK TT. You have to buy a new radiator! He ordered a NA rad cap so we can compare the two.
Haven't managed to check the heaters....I didn't notice them going cold. With all this rain, I'll leave it under the cover and check everything once I have the new cap.
He is talking out of this backside, they are definately available!
I don't stock them but can get them if needed. I have my own 1.3 bar rad caps available too if needed.
If Paul hasn't got one give Steve Manley a call at Inchcape Toyota Oxford, he's pretty much on the ball
parts wise for either UK or J specs 01865 291333
Cheers, guys. :)
Paul, is the 1.3 bar cap rated higher than the OE cap? Could you PM your availability and price posted to Southampton, please?
Ta.
Managed to look over Supes today and immediately noticed the problem...
The top rad hose was loose... at both ends! Tighten it up, refilled the system and bled it. Everything seems to be 100% again.
Just one thing... can anyone confirm what sounds like an air leak coming from the power steering pump region as normal?
Guest Roger NE
I must say, my local Toyota Dealer are GREAT at getting parts . . . even spend ages on the phone with you to identify something silly like a bolt or a spring clip that costs £1-50 . . and order it so it arrives the next day . . . then phone you to tell you it's arrived. First class service!
Maybe we should start a Name & Shame/Praise Toyota Dealers thread on here?!
Personally though, I'd never buy something like a Radiator Cap from a Main Dealer ! (Just as I'm sure you wouldn't buy a new battery or brake pads)
This just when the car is running mate or when turning the steering from lock to lock? Doesn't sound to normal to me :/
Scary someone left it like that and good news you spotted it.
Shouldn't be any leaks down there, have you checked the ps reservoir, any bubbles in it when you turn
the steering ?
Just as it's idling. Don't remember the sound being there before. Could be coming from the throttle body...
the steering ?
Didn't notice any bubbles, but will have a check tomorrow. I think I'll get some leak detector spray in the meantime and have a little investigate.
  • 1 month later...
Just run it, it will self bleed if everything is working as it should.
Just keep one eye on the temp gauge and check the levels in the rad
and expansion tank when its cool.
Rad should be full to the filler neck, check the hose from the rad
neck to the expansion tank is okay, i had one that had a little split
in it a while ago and let air get drawn back into the system.
