wheel nut specs needed please
Guest balloo
hi guys,
what spec wheel nuts are compatible with the supra? i keep seeing M12x1.5 or m12x1.25 etc.....no idea what these numbers mean or what numbers shall i look for when buying a set for supra. thanks for your help in advance.
hi guys,
As above - M12 x 1.5 is what you need :)
As for what the numbers mean, M12 refers to a 12mm nominal diameter ISO metric thread. The 1.5 is the pitch, being 1.5mm from crest to crest on the thread. :thumbs:
