SupraLEDrears Posted November 7, 2013 Share Posted November 7, 2013 Hi Has anyone got a few pics, pointers, etc on replacing the rooflining, please? Can't seem to find anything by searching. Quote Link to comment Share on other sites More sharing options...
listy Posted November 7, 2013 Share Posted November 7, 2013 Really simple Remove the drivers side A-pillar trim (it pops off) Remove the passenger grab handle (it pulls off upwards at the top, and down at the bottom. Undo the two screws behing the grab handle and pop the passenger A-pillar trim off. Pop the cover off the interior light, and undo the two screws underneath. Remove and unplug. Remove the visors, and clips. Now this next bit is optional. Remove all the upper rear trim. Or, you can leave it in, but it is harder to get the roof lining back in. You need to ensure you remove the coat hooks in the back, and the top most screw in the trim (located behind small circular covers) The roof lining will pull out then. To put it back in, exactly the same, but in reverse Quote Link to comment Share on other sites More sharing options...
Rich.2211 Posted November 7, 2013 Share Posted November 7, 2013 Remove interior light, remove A pillar plastics and remove rear quarter plastics and the head lining will slide out the boot IIRC. Quote Link to comment Share on other sites More sharing options...
wile e coyote Posted November 7, 2013 Share Posted November 7, 2013 Is this the same process if I wanted to remove the rear tail gate ? Quote Link to comment Share on other sites More sharing options...
SupraLEDrears Posted November 7, 2013 Author Share Posted November 7, 2013 Thanks guys ill give it a go tomorrow Quote Link to comment Share on other sites More sharing options...
