Auto to Manual Conversion Help Please!
mk1its
Hi guys
We've hit a snag whilst converting the TT Auto to Manual using a W58 gearbox purchased from Aspire earlier this year.
It seems the speedo on the Auto box was electronic whereas the speedo on the W58 is mechanical ie. wire? Is this right????
If so, what do we need to do to make the mechanical speedo work?
The w58 I had was from another supra and the plug was exactly the same as on the auto loom. I didn't need to change anything with the speed sensor, simply plugged it in and everything worked as it was intended :) My guess is your w58 isn't from a MKIV supra.
This is definatley a mkiv w58 it was collected from srd..... the op has now admitted its a mkiv also via pm.....there is now a dispute on regarding.....well im not sure what its regarding but will be addressed once off shift this morning...
I dont think peoples views or opinions regarding the box will help the resolution process
