ccssupra Posted November 4, 2013 Share Posted November 4, 2013 Hi, I have a twisted hub carrier, and I just want to know if any hub carrier is compatible with the OEM big brakes ok my import TT. Its a 1994, im not even sure if it has abs! Quote Link to comment Share on other sites More sharing options...
David P Posted November 4, 2013 Share Posted November 4, 2013 (edited) ABS or non ABS is the difference. Backplates are swappable or choppable. If it's near side rear with no ABS then you're in luck. http://www.mkivsupra.net/vbb/showthread.php?206979-N-A-diff-n-s-drive-shaft-and-hub Edited November 4, 2013 by David P (see edit history) Quote Link to comment Share on other sites More sharing options...
bignum Posted November 4, 2013 Share Posted November 4, 2013 All tt`s have abs mate;) Quote Link to comment Share on other sites More sharing options...
David P Posted November 4, 2013 Share Posted November 4, 2013 I didn't know that, the supercharged model has it only on the rear n.s. hub. Thought I'd found a new home for this old Supra trinket I've had ever since. Quote Link to comment Share on other sites More sharing options...
